#66459 - 07/01/21 01:14 PM Financial Reporter Crashes on Print
JWH Offline
John Hancock, CPA
Loc: London, ON
Have a situation with Ledger V9.3B(210527). On a network environment. Two users who use the Ledger and Financial Reporter.
One can print financial statements or any report without issue. The other as soon as they attempt to print from the financial reporter screen, the screen just disappears and goes away and of course no printing has taken place.
Yet the workstation in question can print any other reports from Adagio including all of the reports in Ledger - Chart of Accounts, Trial Balance, Detail Listing etc. without issue.
I thought it might be the Workstation Option setting - tried both - Specific and Default and same result all reports print OK but the financial reporter crashes.
Any suggestions on what to look for on this one workstation?
Thanks in advance.
#66463 - 07/02/21 07:18 AM Re: Financial Reporter Crashes on Print [Re: JWH]
Dan_Desautels Offline
Loc: Thunder Bay, ON, Canada
Check out this thread: https://portal.softrak.com/ubbthreads/ubbthreads.php/topics/58910/1
It's an older thread, but it may help.
Dan Desautels
DezTek Solutions Inc.
Thunder Bay, ON
#66464 - 07/02/21 08:24 AM Re: Financial Reporter Crashes on Print [Re: Dan_Desautels]
JWH Offline
John Hancock, CPA
Loc: London, ON
Thanks Dan for the link. Will do some checking when I can get back on the workstation in question and post what I find.
Thanks again.
#66736 - 08/24/21 11:55 AM Re: Financial Reporter Crashes on Print [Re: JWH]
Hi all
Today I had a client report the exact same issue as the first post on this thread. Same version of Ledger, and I had recently (in the past two weeks) installed the Ledger update.
I renamed the \Softrak\Ledger\X64 folder and now it prints fine. This was not mentioned in the thread that Dan linked to.
I guess there is a problem with the 64-bit version of Financial Reporter on this system. With the X64 folder renamed, Adagio reverts to the 32-bit version of FR, and that one works fine.
I might add that this is at least the second client for whom this solution has worked. Although it does come back whenever a Ledger upgrade (or possibly service pack) is installed.
#66740 - 09/01/21 08:23 AM Re: Financial Reporter Crashes on Print [Re: Steve Schwartz]
Carol Wojick Offline
Loc: Calgary
I had exactly the same thing happen to me as Steve.
I renamed the \Softrak\Ledger\X64 folder and they are able to print.
Carol Wojick
CW Consulting
#66741 - 09/01/21 08:36 AM Re: Financial Reporter Crashes on Print [Re: Carol Wojick]
Thank you for the confirmation, Carol,
I have updated the problem report with your comments. Please let me know the versions of the x32 and x64 Financial Reporters. I will start adding that to the case information.
#67036 - 10/18/21 09:02 AM Re: Financial Reporter Crashes on Print [Re: Softrak Support]
Ken A. Offline
Loc: Kamloops, BC
HI Dan and Steve,
Thanks for the tips. Renaming the folder worked for me as well.
Support,
Where do I find the files so I can get you the version numbers?
Ken Aberdeen,CPA, CMA
Aberdeen Business Consulting Ltd.
ken@aberdeenconsulting.ca
#67040 - 10/18/21 10:02 AM Re: Financial Reporter Crashes on Print [Re: Ken A.]
Hi Ken,
\Softrak\Ledger\LedgerFinRep.exe and \Softrak\Ledger\x64\LedgerFinRep64.exe. Either check the File Properties from Windows Explorer, or run the EXE and look at Help / About within the application.
#67041 - 10/18/21 10:02 AM Re: Financial Reporter Crashes on Print [Re: Ken A.]
Hello Ken,
Check the properties, Details tab for the file version for the Ledger or FX FinRep.exe and theLedger or FX FinRep64.exe.
For Ledger, the files are here:
Softrak\Ledger folder has the x32
Softrak\Ledger\x64 has the x64
#67043 - 10/18/21 10:23 AM Re: Financial Reporter Crashes on Print [Re: Softrak Support]
Ken A. Offline
Loc: Kamloops, BC
Hello Support,
Under Softrak\Ledger\LedgerFinRep.exe - 2.1.8.2761
Under Softrak\Ledger\x64\LedgerFinRep64.exe - 2.1.8.2761
0 registered (), 21 Guests and 2 Spiders online.
1849 Members
14266 Topics
Max Online: 359 @ 11/18/19 09:08 PM
