#51407 - 10/31/16 03:07 PM Financial Reporter Drill Down
Lyndon_Olfert Offline
Loc: Winnipeg
Andrew and I had a conversation recently about the ability to drill down to the transaction detail (balanced entry) from financial reporter.
I have discovered that this is impossible if one has edited the (Tx) Detail and unchecked the following boxes: Batch #, Entry #, Detail #
Has anyone produced a "Minimum Requirements" for the (Tx) Detail fields required to drill down to the balanced entry?
Lyndon Olfert, CPA, CGA, CAFM
#51409 - 10/31/16 03:25 PM Re: Financial Reporter Drill Down [Re: Lyndon_Olfert]
Hi, Lyndon,
Please select Help | About while in the Financial Reporter and tell us what version you are running.
Do you have any other fields disabled in the Tx Details view? I ask because, I am able to drilldown without those fields enabled and without the Journal Entry field enabled either.
Are you receiving a particular message when you try to do the Tx Details drilling?
#51412 - 10/31/16 03:38 PM Re: Financial Reporter Drill Down [Re: Softrak Support]
Loc: Winnipeg
2.1.6.2395
Previously we had the following fields selected:
Type
Trx Date
Trans Description 2
Reference
With those fields we could not drill down to the balanced entry.
After adding Batch #, Entry #, and Detail #, we can.
#51413 - 10/31/16 04:03 PM Re: Financial Reporter Drill Down [Re: Lyndon_Olfert]
Sorry, Lyndon, I didn't take this far enough before.
It's the Batch # and Entry # being disabled that cause your issue.
With the Batch # and Entry # disabled, you can't get to the 2nd drilldown window, because the FR has been told not to show that specific information.
Enable the Batch # and you get the 2nd window but there's nothing to display because the Entry # is disabled and this window displays entries and their details, just not the specific detail #s.
This makes sense to me. A site might want to prevent users from seeing that much detail.
I'll run it by R&D for you though.
#51414 - 10/31/16 04:19 PM Re: Financial Reporter Drill Down [Re: Softrak Support]
Hi, Lyndon,
R&D's confirmed that the 'index' fields have to be available in the grid to show that information. If you use the DDE for the G/L Posted Transactions (which is really what you're drilling down to), you'll see what the index fields are -- Batch # and Entry # being they most key.
#51415 - 11/01/16 03:21 AM Re: Financial Reporter Drill Down [Re: Softrak Support]
Loc: Winnipeg
Glad I was on the right track! Thanks
14672 Topics
