#32749 - 07/27/12 04:18 PM Mass On Holds
Barb9 Offline
Adagio Prodigy
Loc: Langley
We are using AR 9.0C, and have been playing with the "calculate customer aging" from the Maintenance menu. I really appreciate this function, as it normally takes a really long time to go through one by one and put customers on hold. However, I need to tweak what I am doing a bit, and wondered if there is a different way to approach this function.
Most of our customers are coded to Net 30, but when I run the auto function, it puts anyone even 1 day past their terms on hold. We don't normally put a customer on hold till their invoices have aged to 45 days. Is there a way to do that using the auto function? Maybe I am not setting the fields correctly?
Thanks very much.
Barb
#32750 - 07/27/12 04:25 PM Re: Mass On Holds [Re: Barb9]
Hi Barb,
When you use Calculate Customer Aging, there are amounts under each of the aging columns, which are used for the setting on hold. If a customer has an aged amount greater than this amount, then the customer is put on hold.
If you have an amount greater than zero in your first aging category (1-30 days, 1-15, or whatever you use), then this will put all customers with an amount in this aging category on hold. Set this amount to 0.00. Only have non-zero threshhold amounts in aging categories more than 45 days.
There is a ShowMeHow training video on Calculating Customer Aging in case this is helpful.
#32751 - 07/27/12 04:41 PM Re: Mass On Holds [Re: Softrak Support]
Barb9 Offline
Adagio Prodigy
Loc: Langley
Worked perfect, thank you VERY much. I knew I was doing something wrong! Have a lovely weekend.
Barb has left the building!
0 registered (), 48 Guests and 3 Spiders online.
14666 Topics
