#32428 - 06/27/12 01:18 PM Caution: signon failed
JohnK Offline
Good day to you all!
I have just been asked to setup a new set of books which I have done on numerous occasions.
This is to include Ledger, AP & AR.
The account I am using is the SYS account and it works everywhere to open folders with full rights - the user ID & password combination is correct.
However, when trying to add these new books I am getting the message noted above: "Caution: signon failed" and the data sets are not created.
Any assistance would be most helpful.
Thank you and,
Cheers, JK
#32429 - 06/27/12 01:27 PM Re: Caution: signon failed [Re: JohnK]
Have you created the datasets? Is the path and data extension correct?
#32430 - 06/27/12 01:37 PM Re: Caution: signon failed [Re: Retired_Guy]
JohnK Offline
Thank you for your prompt responce.
The path I usually follow is to:
1. Ledger - data creation - provide folder and extension
2. AP - data creation - provide folder and extension
3. AR - data creation - provide folder and extension
Starting with creating the Ledger data
a- I answer "Yes" to the confirmation dialog
b- I "Ok" the EZfile Directories
The system responds with an error dialog stating the message noted above.
I have tried this on:
1- our standard ACL network controlled folder,
2- a network share with no restrictions,
3- a local folder with no restrictions.
They all yield the same result.
Thank you and,
Cheers, JK
#32431 - 06/27/12 01:42 PM Re: Caution: signon failed [Re: JohnK]
You haven't filled in the password correctly before clicking the "Create" button.
#32432 - 06/27/12 01:45 PM Re: Caution: signon failed [Re: Retired_Guy]
JohnK Offline
The password is correct - I've checked the obvious...
I use this to open the other data sets w/o a problem...
Cheers, JK
#32434 - 06/27/12 01:55 PM Re: Caution: signon failed [Re: JohnK]
Hi JohnK
Copy the ADSPROF.xxx (where xxx is the data extension) from another dataset where SYS works to this dataset location.
#32436 - 06/27/12 04:06 PM Re: Caution: signon failed [Re: Steve Schwartz]
JohnK Offline
Hi Steve,
That did it - I guess the file that is being copied into the new folder is corrupted correct?
Should I copy a good file back up - if so, where to and using what extension?
Thank you - this has been very helpful!
Cheers, JK
#32437 - 06/27/12 06:49 PM Re: Caution: signon failed [Re: JohnK]
No, it's not corrupted, it was just pointing to a different list of users.
That file gets backed up whenever you do a complete backup under File | Backup.
#32438 - 06/28/12 06:24 AM Re: Caution: signon failed [Re: Steve Schwartz]
JohnK Offline
Hi Steve,
This is really weird because I have created numerous companies over the years and never had this problem.
I just retried the operation on a local drive and the only way to make it work was to do your trick.
I have done a full backup of one of our systems including an integrity check and then tried to create a new data set once again but with no success.
What do I need to fix so that this issue is corrected? i would hate to be caught in a position down the road where we cannot add data sets and then we need to get the heavy weights in to "tap the fridge in the right spot"!
<grin>...
As always, thank you and,
Cheers, JK
#32439 - 06/28/12 06:32 AM Re: Caution: signon failed [Re: JohnK]
The Adagio Opportunity Conference is where you learn about fridge tapping.
0 registered (), 459 Guests and 5 Spiders online.
14627 Topics
