#31901 - 05/17/12 10:27 AM Re: Forcing Serial Numbers in Inventory [Re: doug]
OK, but if you don't want to ship any, then presumably you just don't print the picking list until you want to ship. There is a status on the order as to whether the picking slip has been printed.
#31902 - 05/17/12 10:38 AM Re: Forcing Serial Numbers in Inventory [Re: Retired_Guy]
doug Offline
Doug Parrington
Loc: Winnipeg
Yes, but the customer wants the rest of their order.
Doug
#32357 - 06/21/12 03:36 PM Re: Forcing Serial Numbers in Inventory [Re: Barb9]
Barb9 Offline
Adagio Prodigy
Loc: Langley
So me again...
I've done what was suggested on page 1,
"On the 'System Defaults' tab in OrderEntry there is an option 'Serial Entry Mode' that option can be:
'None', 'Auto', 'Prompt' (Press F1 in the app for details)".
I must be having a bad day, though, because nothing changes when I make the change on the Profile tab. Does not matter if I have 'none' or 'auto' or 'prompt'. The same thing happens for each trial I run. No automatic serial number pops up, no prompt happens. Is there a second part to this? I do have the item tagged to have 2 serial lines.
Barb
#32360 - 06/21/12 04:48 PM Re: Forcing Serial Numbers in Inventory [Re: Barb9]
Barb:
Each item has to be configured to allow entry of Serial numbers. Edit the item in IC, select the "Units" tab and enter a number between 1 and 5 into the "Serial numbers" field. That number determines how many serial numbers can be attached to each line item in OE.
#32365 - 06/22/12 07:16 AM Re: Forcing Serial Numbers in Inventory [Re: Bruce Gardner]
Barb9 Offline
Adagio Prodigy
Loc: Langley
As I mentioned in the last sentence I wrote, we already have each of the items tagged, in inventory, with 2 serial numbers each (some of our serial numbers are longer, so we need 2 lines). I have tested this out, and cannot make the prompt come up, nor the auto, so I must be missing a second half of the equation.
We do have the item tagged in inventory. Is there a second area that needs to be touched?
Barb
#32375 - 06/22/12 08:35 AM Re: Forcing Serial Numbers in Inventory [Re: Barb9]
Hi Barb,
The option just controls whether the serial number lines are automatically added to the order/invoice (Quantities must be shipped for the lines to be added). Someone must edit the lines to insert the serial numbers.
My guess is that you are looking for a different behaviour?
I've attached a GridView workspace that I think displayed the lines on an invoice where the necessary serial numbers have not been entered (up to a maximum of 5). Perhaps someone can tell me if it is useful (or indeed whether it even works - the sample data is pretty limited).
SerialNoVerify.zip (78 downloads)
Edited by Andrew Bates (06/22/12 11:13 AM)
Edit Reason: Added GV Workspace
0 registered (), 107 Guests and 2 Spiders online.
1869 Members
14602 Topics
