#24503 - 10/18/10 08:26 AM
Receivables and the F6 Key
Adagio Prodigy
Loc: Langley
We recently upgraded to Recievables 9.0B We are running into the same error message whenever anyone uses the F6 key. I have tried searching by Report Group, Customer Name, and Customer Phone Number. All 3 searches return the same error:
"Internal Error: field (211) of (@R90ACT9) is not a boolean field"
Any ideas on what may be going on? Thanks very much.
Barb
#24504 - 10/18/10 08:37 AM
Re: Receivables and the F6 Key
[Re: Barb9]
Adagio Prodigy
Loc: Langley
We are going to try re-installing AR 9.0B, because of the Lanpak issue we had last week. Will let you know if that fixes this problem.
Barb
#24505 - 10/18/10 08:49 AM
[Re: Barb9]
Adagio Conductor
From my tests, I believe the problem is restricted to those with Time & Billing data present.
#24506 - 10/18/10 08:57 AM
[Re: Bob Wisener]
Adagio Prodigy
Loc: Langley
We did re-install our Lanpaks, this did not fix the problem. We are not running Time and Billing at all.
It seems this is an error in the module?
Barb
#24507 - 10/18/10 09:15 AM
[Re: Barb9]
Adagio Conductor
Time & Billing stores client information in the following data files, ARCLNT'I and ARCLNT'R. If these data files are present, AR will generate the error. If you're not using Time & Billing, I believe these two files can be removed. How they got there, I'm not sure.
#24513 - 10/18/10 10:07 AM
[Re: Softrak Support]
Adagio Prodigy
Loc: Langley
We did drill down to the Softrak\Dict folder, the dates of the @R901Al.ssi and @R90AR.ssi files are 9/14/2010, which is the same date we did the install to AR9.0B
We also checked for the files mentioned by Mr. Wisener, they do not exist in our database.
Barb
#24530 - 10/18/10 01:16 PM
Adagio Prodigy
Loc: Langley
Definitely no files that start with TB. The only Adagio module we are running into this for is AR. When we have the customer list open, and hit F6. Does not matter what you type in for the program to search, the error as shown in the first post here is displayed. Release date is 100910. AR 9.0B
Barb
14632 Topics
