#22603 - 06/08/10 06:46 AM FINREP.EXE Runtime Error
Tony Martin Offline
Loc: Chatham, Ontario, Canada
GL 9.0B (090713), previously working fine.
Now when trying to open Financial Reporter receive error message Runtime Error! in LedgerFinrep.exe
The application has requested the Runtime to terminate it in an unusual way...
Thoughts?
Tony Martin
Code 6 Programming
519.359.0918
#22604 - 06/08/10 09:01 AM Re: FINREP.EXE Runtime Error [Re: Tony Martin]
Well - something changed or a file is damaged. If this is occurring before the financial reporter is even off the ground, then, if it is a file, it's likely one of the files, GLATREE.dat (the spec code file), GLDTREE.dat (the department tree), GLRPTGRP.dat (the statement groups), GLACCGRP.dat (the account groups).
#22606 - 06/08/10 10:31 AM Re: FINREP.EXE Runtime Error [Re: Retired_Guy]
Tony Martin Offline
Thanks Andrew, I'll load them from a backup.
By the bye, are these checked by the Integrity Checker?
Tony Martin
Code 6 Programming
519.359.0918
#22607 - 06/08/10 10:34 AM Re: FINREP.EXE Runtime Error [Re: Tony Martin]
No. They are not regular "Adagio" files.
BTW - does the finanacial reporter open when you're in the sample data?
#22608 - 06/08/10 10:54 AM Re: FINREP.EXE Runtime Error [Re: Retired_Guy]
Tony Martin Offline
Yes, opens fine in Sample and other company data...
Tony Martin
Code 6 Programming
519.359.0918
#22617 - 06/08/10 01:59 PM Re: FINREP.EXE Runtime Error [Re: Tony Martin]
OK - it's probably one of those files then. If you just rename them they will be recreated when you launch the financial reporter.
0 registered (), 187 Guests and 4 Spiders online.
14567 Topics
