#8525 - 03/01/07 12:21 PM Archive of Bank Rec Templates
Fullen Offline
Adagio Fan
Loc: Banff
(207.148.169.30)
In order to use bank rec for my deposits, I have needed quite a complex journal entry template and wouldn't want this to inadvertently get deleted one day.
Is there a way to archive the bank rec templates?
#8527 - 03/01/07 12:43 PM Re: Archive of Bank Rec Templates [Re: Fullen]
When entering either receipts or payments in Adagio BankRec, you can use a Distribution Set to enter a standard set of GL distributions. So if a deposit requires a particular set of distributions, you can enter these into a Distribution Set and select this during batch entry. Is this the template you are referring to?
If you are concerned about accidentally deleting a distribution set code, perhaps you could use the security Groups to disable access to the function, so nobody can delete them.
Or if you do not plan on adding new distribution sets, you could backup the related data files. And if something inadvertant happened, you could restore only these files. Before restoring data files in this way, always make a complete backup of your data, in case you inadvertantly do something unintended. There are 4 data files that all start with BRDST: BRDSTD'1, BRDSTD'R, BRDSTH'1 and BRDSTH'R.
#8583 - 03/07/07 12:47 PM Re: Archive of Bank Rec Templates [Re: Softrak Support]
Fullen Offline
Adagio Fan
Loc: Banff
(207.148.169.30)
A distribution set may work... I'm not sure. Carol helped me and I think this may be the answer.
Thank you
Edited by Fullen (03/07/07 03:39 PM)
1 registered (rah), 76 Guests and 2 Spiders online.
1874 Members
14555 Topics
