#8214 - 01/05/07 01:54 PM GridView
Barb9 Offline
Adagio Prodigy
Loc: Langley
Is there a gridview report which I can draw from inventory that will show me the quantity on hand, by location?
Thank you.
#8216 - 01/05/07 03:24 PM Re: GridView [Re: Barb9]
Barb,
There isn't a report just like this in sample data. However, you can create one yourself.
Create a new view, Adagio Inventory 8.0a/b module, then select the I/C Item Locations table. From there select the Item #, Location and Qty on Hand Plus fields. You will probably want to save your view 'without' data and for the view to refresh on open. Give your view a name.
After you create the view, you can select the Item # column and set the sort order. Then when the sigma/summarize button in the toolbar is selected, you will be able to see the total qty on hand for all locations for each item also. This is a toggle button.
2 registered (Warren Karges, Howard S.-MMA), 106 Guests and 2 Spiders online.
14668 Topics
