Page 3 of 3 < 1 2 3
#7569 - 10/10/06 03:35 PM Re: Good resource for GridView?
For more infrmation about how to use GridView, make sure you sign up for one of this month's Adagio User Group web seminars. Warren will be showing how to create inquiries using filters and calculated columns. He'll also preview some of the improvements coming in the next release. If you have a specific feature you'd like demonstrated, don't forget to ask about it when you register for the session.
#40274 - 02/20/14 07:39 AM Re: Good resource for GridView? [Re: Retired_Guy]
MikeS Offline
Loc: Concord, On
Originally Posted By: Andrew Bates
To have the View "ask you" for a range of item numbers, use this fiter:
Code:
AND(
  UPPER(TRIM({Item #}))&gt;=UPPER(TRIM(QUERYSTRING("Starting item?", ""))),
  UPPER(TRIM({Item #}))&lt;=UPPER(TRIM(QUERYSTRING("Ending item?", "zzzzzzzzzzzzzzzz")))
For date ranges use "=QUERYDATE()".
I asked the same question about the transaction codes in IC history the other day. Here are the values:
Code:
 Trx Trx
 Src Type Description
 1   1    Receipt
 1   2    Receipt adjustment
 1   3    Receipt return
 2   1    Shipment
 2   2    Shipment return
 3   1    Adjustment credit
 3   2    Adjustment debit
 4   1    Stock transfer from
 4   2    Stock transfer to
 5   1    Component item assembly
 5   2    Master item assembly
Hope that helps.
Could I find out what these code are:
Trx Trx
3 3 Adjustment ????
3 4 Adjustment ????
3 5 Adjustment ????
3 6 Adjustment ????
#40280 - 02/20/14 09:14 AM Re: Good resource for GridView? [Re: MikeS]
Hi Mike,
There are 6 different kinds of adjustments you can make. You can change just the quantity, just the cost or both, and either an increase or a decrease. That makes 6 combinations of these choices:
1: Qty increase
2: Qty decrease
3: Cost increase
4: Cost decrease
5: Both increase
6: Both decrease
Page 3 of 3 < 1 2 3
0 registered (), 73 Guests and 1 Spider online.
1866 Members
14513 Topics
27 28 29 30 31
