Barb:
You must print the worksheet for the whole rage you are working on, becasue the file you will use to enter adjustments is generated at the same time.
You can, however, print the Physical Inventory worksheet to Excel. Then you can sort by quantity on hand and delete the rows that do not apply before using up a tree or two.
If you discover, while counting, an item for which the computer shows zero on hand, the staff can write it in and it will still be in the list to be adjusted.
Ralph Allan
Business Computer Centre
Prince George BC Canada
