#7122 - 06/26/0606:02 PMImporting a db3 file into Adagio Ledger
Using the import function in Adagio ledger to import monthly financial tranactions from our in house sysyem into Agagio ledger received the following error on 2 of the fields with date values.
"Invalid Date '05/31/2006' in field called 'Fiscal Date" in record 1" Receive same error for field Transaction Date. Receive these errors for all records.
Spoke with our database guy here and he sugguested it may be the windows system date. I tried every date combo I could and received the eooror each time.
If I open the database this is the date format in each of the 2 fields that are failing: 05/31/2006
#7126 - 08/22/0602:18 PMRe: Importing a db3 file into Adagio Ledger
I am trying to import a csv file and get the same error. I have tried to set the system date as detailed and I still get the "Invalid Date '05/31/2006' in field called 'Fiscal Date" in record 1" I do not get an error on the trasnaction date however. It is set to ascii YYYYMMDD format.
I had no issue with this previously but recently I installed a Ledger patch.
