#66498 - 07/09/21 06:15 AM ePrint NFR
JWH Offline
John Hancock, CPA
Loc: London, ON
Want to do some testing with ePrint in the office and don't see it available as an NFR download. Is it not available to download anymore?
John Hancock
John W. Hancock & Assoc. Ltd.
#66499 - 07/09/21 07:42 AM Re: ePrint NFR [Re: JWH]
It's called DocStore now.
#66500 - 07/09/21 07:45 AM Re: ePrint NFR [Re: Steve Schwartz]
Unless your talking about Adagio Cloud, where ePrint is still available, otherwise, as Steve says ePrint is now part of DocStore.
Edited by Douglas Dickie (07/09/21 08:12 AM)
Edit Reason: typo
#66507 - 07/11/21 08:23 AM Re: ePrint NFR [Re: Douglas Dickie]
JWH Offline
John Hancock, CPA
Loc: London, ON
Thanks for the posts.
Even though it is no longer supported and is now part of DocStore it's functionality should still work correct?
I ask since a client is getting the following error when trying to print to PDF (this has just happened in the last few days and they have been fine up until last Thursday):
"Could not read license for printer AdagioV2PDF. Print job will be cancelled."
Just curious.
John Hancock
#66508 - 07/11/21 08:34 AM Re: ePrint NFR [Re: JWH]
JWH Offline
John Hancock, CPA
Loc: London, ON
And as a follow up to the previous post the error for the AdagioV2PDF all workstations on the network are now getting not just one of them FWIW.
John Hancock
#66511 - 07/12/21 07:38 AM Re: ePrint NFR [Re: JWH]
Dan_Desautels Offline
Loc: Thunder Bay, ON, Canada
Since Microsoft recently found and patched a print spooler vulnerability, you should check with the client's IT that they did not temporarily disable the print spooler on the client's workstations while waiting for the patch or the more likely scenario that the Windows patch did not disable the nova pdf service.
Dan Desautels
DezTek Solutions Inc.
Thunder Bay, ON
#66512 - 07/12/21 08:09 AM Re: ePrint NFR [Re: Dan_Desautels]
JWH Offline
John Hancock, CPA
Loc: London, ON
Thanks Dan for the information. Much appreciated. Will contact them to find out.
With that said we did check two of the workstations in question (by that I mean the Nova PDF service) on the local machine and they were running. We stopped it and restarted for you know what and giggles and still the error.
Just so that I am clear does the Nova PDF service read the local service or the server?
Thanks in advance.
John Hancock
#66525 - 07/13/21 12:52 PM Re: ePrint NFR [Re: JWH]
JWH Offline
John Hancock, CPA
Loc: London, ON
Here is what resolved our issue as per the IT guys (which I assume is the issue Dan previously mentioned):
https://msrc.microsoft.com/update-guide/vulnerability/CVE-2021-34527
Edited by JWH (07/13/21 01:05 PM)
John Hancock
#66527 - 07/13/21 01:17 PM Re: ePrint NFR [Re: JWH]
Thanks for the update but your post isn't very clear:
Did installing the patch from Microsoft solve the problem? In which case the problem was caused by IT disabling the print spooler?
#66531 - 07/13/21 02:13 PM Re: ePrint NFR [Re: Douglas Dickie]
JWH Offline
John Hancock, CPA
Loc: London, ON
Don't quote me but it is my understanding this was a MS update issue. All was fine up until last Thursday and then they started to get this issue.
So I assume one of the MS updates buggered something up and MS released this fix which obviously fixed the issue.
John Hancock
1 registered (Howard S.-MMA), 526 Guests and 1 Spider online.
14627 Topics
