#65899 - 04/03/21 09:00 AM
Re: Error Message - Ledger V9.3B(210225)
[Re: JWH]
Stranger
Loc: Ottawa, ON, Canada
I am getting the same error code as described above. I use just one workstation running Windows 7 Pro and have upgraded to Ledger 9.3B (2021.01.15) and SP Ledger 9.3B (2021.02.25). I have not upgraded to SP Ledger (2021.03.31). Before doing the above work-around, I am curious if last week's SP (2021.03.31) will correct this error?
#65901 - 04/03/21 10:31 AM
[Re: Robert]
Hello: The March 31 service pack addressed the issues listed below, plus some improvements to the Financial Reporter. None of them refer to a printing error message. Therefore your best solution for now is to go to File | Workstation Options and set a "Specific" printer as Scott described on March 16. March 31 Service Pack Changes: - Detail only Batch import in Ledger 9.3B(21.02.25) an earlier required the account and department field to both be imported or defaulted. This is no longer required.
- Export transactions did not find any records if the first account/department in the selected range did not have any transactions and the department for the next account/department in the range had a lesser value.
- After printing the Detail Listing report, the data files containing the Account Net Changes were not properly released, until the user closed the program. This caused errors and potentially corrupted data if another user performed a function that required reading or writing to those data files. The release is correctly performed now.
- When an Accounts grid was set to show Active Records only and was changed to remove that setting, Inactive accounts were not correctly refreshing to the correct position and displayed at the end. The View Transactions/Budget did not display any accounts. Both of these situations have been fixed.
- If Company Profile options for Post Invalid Entry to Error Batch and Require Batch Print Before Posting are both disabled, a warning message will appear at sign-on to indicate this is no longer a supported configuration and you need to change either option.
#66220 - 05/27/21 02:15 PM
[Re: Bruce Gardner]
Loc: Thunder Bay, ON, Canada
Just got off the phone with a client where we recently upgraded all their modules. Two users are having the same invalid printer rpt error John describes but in BankRec 9.3A (210427). AP 9.3B (201019) works fine. The culprit printer is a Sharp network printer. One user is on Windows 7, the other on W10. So the behaviour is that when the Sharp Printer is the Windows default printer OR the selected printer in Workstation Options in BR, we get the invalid printer error when previewing or printing any report in BR. If we make the windows default a different printer, no error when previewing or printing.
However, when previewing successfully with the other printer we can then click the print button from the preview window and the Printer selection box that comes up from Windows allows us to choose the Sharp printer and print successfully. I can only assume that's because there is no loading the report from Crystal at that point.
Note: We even tried changing the name of the printer to eliminate any spaces or special characters and shortened it to less than 10 characters. Rebooted and no change.
Edited by Dan_Desautels (05/27/21 02:17 PM)
#66244 - 06/01/21 02:18 PM
[Re: Softrak Support]
The client I described in this thread was not working from home.
#66247 - 06/03/21 08:38 AM
[Re: Dan_Desautels]
Another client of mine has an invalid printer issue. They are getting the error in GL 9.3B (210331) but NOT AP 9.3B (201019). They are not connecting remotely. Similar to my other post above, it's a Sharp Network printer. This client is using Windows 10 and it started when the IT person changed her default printer to the Sharp. Workaround was to change the workstation option in GL to print to a PDF printer.
#66248 - 06/03/21 09:05 AM
[Re: Dan_Desautels]
Adagio
Loc: Vancouver, BC, Canada
Hi Dan, Let me start with I no longer consider myself an IT Network person. Could it be that the way the network printer is setup that the local machine does not have a copy of the printer driver?
A test would be to install the printer driver for the Sharp on the workstation.
Edited by Chris McDonell (06/03/21 09:05 AM)
Chris McDonell Softrak Systems Inc.
#66250 - 06/03/21 09:21 AM
[Re: Chris McDonell]
Hi Chris,
I will have to connect with the client later. But I would counter with: why do Payables reports print fine when that printer is the default? It seems to indicate that only GL has this issue.
0 registered (),
214
Guests and
Spiders online. |
14579 Topics
