#66252 - 06/03/21 12:28 PM
Re: Error Message - Ledger V9.3B(210225)
[Re: Softrak Support]
Loc: Thunder Bay, ON, Canada
Hi Doug, Support's comment contradicts your answer. They also reference AP using V3PDF at other points in this thread. I do not have the error in JobCost or Time&Billing, applications that have not yet been moved over to use AdagioV3PDF and AdagioODBCv3. This might not be coincidence. Maybe this explains why Ledger and BankRec and Payables are seeing this problem and other apps are not.
Although, I suspect the printer driver could be an issue, my question still stands about why AP doesn't have an issue.
#66253 - 06/03/21 12:30 PM
I'd also like clarification on this post. What are the "recent upgrades" that were edited? Because I've seen other online posts about issues with Crystal and RPT reports having to be edited or recreated to get around this issue. In some recent upgrades/releases, we edited every report in the application to save AdagioV3PDF as the default printer on the RPT files, to try and ensure that on the initial load of the Crystal report, the printer driver exists on the client's workstation.
#66254 - 06/03/21 12:49 PM
[Re: Dan_Desautels]
Hi Dan,
I cannot with 100% confidence answer your question why AP does not have an issue. If it is 93B then I might have expected it to, based on other criteria previously discussed. I concur with Doug that this scenario is either AdagioV3PDF or Crystal SP 25 or both. I was mistaken in bringing ODBCv3 into this conversation, as R&D pointed out to me.
I say 'recent releases' meaning upgrades from about Aug 2020 an on, not SPs or HFs. It looks like Payables has not yet had this treatment. Perhaps this is an important consideration for this error, and a difference that means Doug's suggestion is not a contradiction.
The reason for updating all of our reports to assign AdagioV3PDF is that we assume that it gets installed correctly to the workstation, and will exist for all users. Whatever printer driver that R&D uses when they create/modify reports certainly won't exist for all users.
As I indicated earlier in this thread, I also was able to replicate the Invalid Printer Error for some Adagio programs and not others. For both Print and Preview. Older ones don't have the problem for me. The root cause is likely different for me than for your clients, as you indicated, but they might somehow be related to how Crystal is reacting to it - such as Crystal not finding the expected printer driver on the workstation for whatever esoteric reason.
I've brought this up with R&D but to date do not have a known specific cause nor a solution.
I suppose nobody else has the same exact scenario as me, but for the record, Google told me that because my home local printer is a USB printer, the Microsoft Easy Print driver that gets set up via Remote Desktop Connection does not know how to properly redirect print jobs from my remote location to home (include Word and Outlook). Google also told me I have to install the printer driver that I use at home onto my remote computer at work. I'm not IT-savvy enough to know all the whys here.
Regards, Softrak Tech Support
#66256 - 06/03/21 02:07 PM
Hi Support,
Thanks for the detailed response. I'll report back when I get time to investigate further on the printer drivers.
#69957 - 07/18/23 12:51 PM
[Re: Warren Karges]
This is still an issue.
I upgraded a client to the current versions one day ago. Now we cannot print or preview within Adagio from their Sharp MX-3070N.
Terry (Tech Support) tells me there is no solution at this time.
Has anyone come up with a work-around to print to the Sharp printer?
#69958 - 07/18/23 01:20 PM
[Re: Samuel Kopstick]
Sam,
Two options: Client sets their default printer in Windows to a different printer. Then they will have to preview reports in Adagio and change the printer from the print preview window if they want to print to the Sharp. The Print button in the preview window gives you the option to change the printer.
Or, set the workstation options for Reports in each module to print to a different printer or PDF printer. Then the same print preview is required to be able to change the printer to the Sharp.
Second option is better if the client prints from other programs to the Sharp often.
#69961 - 07/18/23 02:57 PM
[Re: Dan_Desautels]
Dan - thank you for your advice. The client is still printing cheques. Hopefully, we will be able to use the Preview strategy also for this.
#69964 - 07/18/23 07:39 PM
Sam,
The Sharp printing issue should not affect printing cheques. The issue has to do with Crystal Reports having an issue loading the Sharp printer drivers when loading a report. Since cheques don't use Crystal, they should be fine without the workaround. That's why I said you should only need to set the workstation options for reports.
1 registered (D_Boon),
132
Guests and
Spider online. |
1865 Members
14419 Topics
