#64046 - 06/01/20 09:52 AM Invoices 9.3A and Inventory 9.3A Heads up
One of the changes with IC 9.3A is the option to Retrieve inventory related transactions from Invoices. This is superior to the previous method of using File | Import, unless the two datasets are in different locations.
But following data conversion to 9.3A, the company profile in Invoices remains set to Import until you change it to Retrieve. End users may be unaware that whereas 9.2A created a file called ICSBATCH.xxx to import, 9.3A creates a file called ICS93BTH.xxx, and the Import template in Inventory will not find the new file name unless you change the template as well.
#64050 - 06/01/20 10:38 AM Re: Invoices 9.3A and Inventory 9.3A Heads up [Re: Steve Schwartz]
Steve:
Thanks for the tip
#64056 - 06/02/20 03:42 PM Re: Invoices 9.3A and Inventory 9.3A Heads up [Re: Douglas Dickie]
Brian Stief Offline
Waterloo Guy
Thanks Steve. Good info.
Brian
Brian Stief,CPA,CA
800.540.3164
0 registered (), 144 Guests and 0 Spiders online.
14643 Topics
