#63273 - 03/10/20 01:10 PM Adagio Payables 9.3B - continual workstation setup
Andrew_Peebles Offline
Adagio Consultant
Loc: Victoria, BC
I am receiving this continual workstation setup loop. Inventory nor Jobcost are installed at this site. I couldn't see any P to remove from the resource flags. I have tried reinstalling AdagioPDF, and same results. Problem is that everytime one starts Payables, the workstation update message appears, and no access to Payables is available. I have contacted the IT support team for this customer, and tried the install again, with Administrator user, and same issue. Also have updated Java, rebooted workstation, renamed c:\softrak\payables and c:\softrak\AdagioPDF and then tried another install.
#63274 - 03/10/20 01:22 PM Re: Adagio Payables 9.3B - continual workstation setup [Re: Andrew_Peebles]
Adagio Payables 9.3B installs a number of new system file processes, including a new workstation Crystal runtime, AdagioV3PDF printer driver and ODBCV3. Like Inventory 9.3A, a lot more than just the application is being installed with this upgrade. In case there are any rights considerations such as the ability to write to the Windows registry or folders, or create new printer drivers. You did say that an Admin user has a similar experience.
There are a number of important notes in the ReadMe file for this Payables 9.3B upgrade. Perhaps check these out in case the procedures that have been done so far is missing something that should ro should not have been done based in the notes.
There is more than one reason why the auto-workstation install would be initiated. If you manually run the workstation setup, or the auto workstation setup that appears, are there any error messages? Or does it appear that the install was successful, but then it happens again?
#63275 - 03/10/20 01:50 PM Re: Adagio Payables 9.3B - continual workstation setup [Re: Softrak Support]
Adagio Consultant
Loc: Victoria, BC
There are no error messages. The install does appear successful - but then it happens again. I did note - that there is not an additional AdagioV3PDF printer created. I did restart the print Spooler, and still no additional printers appearing.
#63288 - 03/11/20 09:23 AM Re: Adagio Payables 9.3B - continual workstation setup [Re: Andrew_Peebles]
Adagio Consultant
Loc: Victoria, BC
Can I please get some assistance with this issue? The Operating System is Windows 7.
#63294 - 03/11/20 11:16 AM Re: Adagio Payables 9.3B - continual workstation setup [Re: Andrew_Peebles]
Andrew:
As Microsoft is no longer supporting Windows 7, Softrak is no longer supporting Windows 7.
If you Google the forum, I'm fairly certain this problem was discussed sometime in the last couple of years.
#63295 - 03/11/20 11:48 AM Re: Adagio Payables 9.3B - continual workstation setup [Re: Douglas Dickie]
Adagio Consultant
Loc: Victoria, BC
Thanks Doug for your suggestion.
The customer has a server and 2 workstations. Both workstations are Windows 7. Adagio Payables 9.3B is working with no issues on one of the workstations, and doing the continual workstation setup loop on the other. I can appreciate that Windows 7 is no longer supported by Microsoft and Softrak - however - hard to tell a customer that is the cause of the problem - when all is working on one of the Windows 7 workstations....
#63301 - 03/11/20 02:17 PM Re: Adagio Payables 9.3B - continual workstation setup [Re: Andrew_Peebles]
Hi, Andrew,
You did mention that there is no AdagioV3PDF printer in this workstation printing and devices. That would certainly be a culprit.
If you do a search in their Control Panel, Programs and Features for Softland, there are potentially 4 components to the AdagioV3PDF printer. None, some or all might show as being installed (along with components for AdagioV2PDF and AdagioPDF.
AdagioV3PDF components:
Adagio Accounting PDF Printer V3
novaPDF SDK Printer Driver
novaPDF SDK10 SDK COM (x64)
novaPDF SDK10 SDK COM (x86)
Uninstall any that are there then close the control panel windows.
Restart the w/s.
Note that the user requires full Admin rights to their w/s to do the install and update their registry.
Next, drill down to the Softrak\System\AdagioPDF folder on the server from the affected w/s.
Local and run the AdagioV3PDF.EXE.
When run, the process shouldn't just 'zip' by but you should see the install working its way through.
When you're done, you should see the AdagioV3PDF printer in the w/s's printers and devices.
Please suggest to the site that they consider upgrading their w/s's to Win10 (or just get new w/s's). Microsoft has been pretty clear that they will not be providing more security updates for Win7. Not doing so puts them at risk.
#63303 - 03/11/20 02:59 PM Re: Adagio Payables 9.3B - continual workstation setup [Re: Softrak Support]
Adagio Consultant
Loc: Victoria, BC
Hello Softrak tech support.
Thank you for your additional suggestion. I was able to resolve this issue, and suggested to the site, upgrading workstations to Windows 10.
I went through add/remove programs and uninstalled the novaPDF SDK10 SDK COM (x86), Adagio Payables, and SAP Crystal ... Then I ran the Payables Workstation setup executable, using "Open", rather than Run as Administrator. After this, Adagio Payables 9.3B opened successfully, without the workstation setup loop. I don't know precisely which of the above efforts resolved the issue - but all is working presently.
Edited by apeebles (03/11/20 03:00 PM)
0 registered (), 177 Guests and 7 Spiders online.
14578 Topics
