#61007 - 06/04/19 06:05 AM NovaPDF error after updating modules
KNoel Offline
Loc: Ottawa ON Canada
We've just updated all of our modules to the most recent versions and are getting an error message when printing to AdagioPDF: "Failed to create novaPDF COM object".
Is there an update to AdagioPDF that we're not aware of?
Karin
#61009 - 06/04/19 07:02 AM Re: NovaPDF error after updating modules [Re: KNoel]
Vickie_zaam Offline
zaam.ca
Loc: Ontario
Hi Karin,
-is it happening on all workstations?
-was there a workstation installation done?
1-try rebooting the computer
2-if that does work, you can reinstall the pdf using \softrak\system\AdagioPDF\ReinstallAdagioPDFxXX.bat (pick 32 or 64 depending on your computer OS)
Vickie Cegliastro
zaam.ca
613-532-6229
#61022 - 06/04/19 11:23 AM Re: NovaPDF error after updating modules [Re: Vickie_zaam]
KNoel Offline
Hi Vickie,
I tried:
1-rebooting, no change
2-reinstalling using the network path (64bit), reboot, no change
3-copying the folder in 2 to the c: and reinstall, reboot, no change
4-uninstalling the AdagioPDF (novaPDF 7), reinstalling using the network, reboot, no change
Any other options I can try?
Karin
#61023 - 06/04/19 11:44 AM Re: NovaPDF error after updating modules [Re: KNoel]
Did you run the install as Administrator?
#61025 - 06/04/19 12:00 PM Re: NovaPDF error after updating modules [Re: Retired_Guy]
KNoel Offline
Ah no, I did not! Let me check with my IT "guy" and see if he's able to do some magic I can't do...
#61026 - 06/04/19 12:04 PM Re: NovaPDF error after updating modules [Re: KNoel]
KNoel Offline
Just checked with IT and they confirm I do have administrator access on my computer.
It shows the printer driver re-installed but the same error message appears.
#61027 - 06/04/19 12:12 PM Re: NovaPDF error after updating modules [Re: KNoel]
Hi Karin,
One other site that ran into this error message restarted the NovaPDF COM print server.
When uninstalling, most current versions of Adagio use the AdagioV2PDF (Nova 8.7) rather than the original AdagioPDF (Nova 7) driver. Do you have both AdagioPDF and AdagioV2PDF on the workstations?
#61029 - 06/04/19 12:37 PM Re: NovaPDF error after updating modules [Re: Softrak Support]
KNoel Offline
I do have both printer drivers installed but was always told to use only the non-V2 version.
#61030 - 06/04/19 12:44 PM Re: NovaPDF error after updating modules [Re: KNoel]
I believe that all current versions of Adagio call AdagioV2PDF.
#61031 - 06/04/19 12:50 PM Re: NovaPDF error after updating modules [Re: Retired_Guy]
Vickie_zaam Offline
zaam.ca
Loc: Ontario
Karin, try printing with v2. Don't know why you were told not to use it, but it should be fine and probably takes care of this issue.
Vickie Cegliastro
zaam.ca
613-532-6229
0 registered (), 200 Guests and 7 Spiders online.
14568 Topics
