#55486 - 10/30/17 12:53 PM Financial Reporter crashing
bd Offline
Loc: Peterborough, ON
(72.38.104.206)
Lately when I bring up a report in financial reporter and print, whether it's to a printer or a .pdf, FR crashes. It gives me the option to restart or close and I get recovered files (last saved versions) for whatever reports I had open when FR re-opens.
However interestingly enough, if I use statement group print, it all works fine. But sometimes I don't want to print a whole set or setup statement group print for every report I might run one at a time
I am using v9.3A (170625) and going into financial reporter both times, not printing from the ledger menu.
Barb
#55487 - 10/30/17 12:59 PM Re: Financial Reporter crashing [Re: bd]
Hi Barb,
We've had a couple of sites report similar behaviour, interestingly starting around the time that this month's Microsoft Windows Updates were installed.
One of these sites sent us the Windows Event Manager log, and the particular error message was connected to this Microsoft link that R&D gave to tech support.
This is all I know about this particular situation. We're keeping our eyes on this error but we currently don't know if the problem is within our control to address it.
Excel Direct also worked for this site, if you need to print a one-off statement (from Excel).
#55803 - 12/14/17 05:00 PM Re: Financial Reporter crashing [Re: Softrak Support]
We are having the same issue on our 2012R2 TS. I don't even print. I hit the print button and then cancel the print window and the Financial Reporter crashes and we can only close the program.
This is not new but I haven't had the time to investigate it before and it has not been reported by any of our clients. It happens with GL 9.2B or GL 9.3A. I haven't checked earlier versions.
The link you posted may not apply as our Office works fine and it is from 2010. However, we noticed it in October but we didn't do any Windows updates in October. Our previous Windows update was a the beginning of September. We installed DocStore preview at the end of September.
#55804 - 12/15/17 06:40 AM Re: Financial Reporter crashing [Re: Patricia B.]
Warren Karges Offline
We just had a site report this to us as well. I haven't been able to collect all the details but they reported exactly the same thing as the original poster and also run the June release GL 9.3A via RDP on server 2012R2.
Warren
#55815 - 12/18/17 09:18 AM Re: Financial Reporter crashing [Re: Warren Karges]
On a Terminal Server, Adagio is installed as Administrator. If I login as Administrator, it doesn't crash. I think, a more current install may have changed the registry or the location of temp files.
#55818 - 12/18/17 11:21 AM Re: Financial Reporter crashing [Re: Patricia B.]
I tested with another profile and it worked properly. Therefore, I thought it was my own registry. Deleted the Financial Reporter entry and it works fine now.
The other user may have never used the Ledger before. Something got corrupted in one of the updates.
Edited:
The other user works. Mine still doesn't. We are both on the same Terminal Server.
Edited by Patricia B. (12/18/17 11:51 AM)
#55832 - 12/19/17 11:37 AM Re: Financial Reporter crashing [Re: Patricia B.]
I can also confirm that different windows users in same server 2012r2 RDP environment have different outcomes using the same financial statements. Can't say what the key difference is between windows user accounts, but that must be part of the problem.
Not sure why using the statement group print seems to get around the issue but I have confirmed that is a workaround for my client as well.
Warren
#55981 - 01/11/18 09:21 AM Re: Financial Reporter crashing [Re: Warren Karges]
Dan_Desautels Offline
Loc: Thunder Bay, ON, Canada
(50.70.188.43)
I too have a client with the same issue. Her profile crashes on print from the Financial Reporter and others do not. 2012r2 RDP environment as well. GL 9.2B (20170320)
Has anyone got any further on this?
Dan Desautels
DezTek Solutions Inc.
Thunder Bay, ON
#55982 - 01/11/18 10:10 AM Re: Financial Reporter crashing [Re: Dan_Desautels]
I do have the solution if you want to call me. I did a number of changes and I am not sure which one was the one that solved it.
We can try one at the time and know for sure.
#56621 - 03/01/18 01:04 PM Re: Financial Reporter crashing [Re: Patricia B.]
Was anyone ever able to isolate what setting(s) were the cause? There seems to be more than infrequent reports of this, and if the solution is a setting in Windows for the workstation or the server, I'm sure the community would benefit from the answer.
1 registered (1 invisible), 251 Guests and 1 Spider online.
1874 Members
14561 Topics
