#5661 - 02/20/06 09:44 AM Vendor invoice count ... unfixed
doug Offline
Doug Parrington
Loc: Winnipeg
Datacare runs every night, and every morning i get the following error "invoice count is 956 found is 0 Checking Vendors... ... 1 error(s) found " any ideas on what this is or how to correct it is greatly appreciated.
Thank You
Doug
#5662 - 02/20/06 03:22 PM Re: Vendor invoice count ... unfixed
Hello doug,
What does the File | Check Data Integrity report in Adagio Payables? It might offer you a chance to fix the problem.
#5663 - 02/21/06 08:27 AM Re: Vendor invoice count ... unfixed
doug Offline
Doug Parrington
Loc: Winnipeg
Hi Andrew
thanks for the reply, when I run the integrity check in payables, I get the same sort of message in the Application Integrity Phase "Vendor invoice count is 865 found is 0
Checking Vendors... ... 1 error(s) found"
Doug
#5664 - 02/21/06 04:54 PM Re: Vendor invoice count ... unfixed
Make a backup (File|Backup).
Then run Data Integrity Check, after the error appears click on Rebuild, then repeat until Data Integrity Check reports no errors.
If the errors persist even after running Data Integrity Check a few times, your data is seriously corrupted.
