#56518 - 02/21/18 09:20 AM Can not install Bank Rec update
corishuey Offline
Stranger
Loc: nj
(24.47.133.179)
When I attempt to install the latest update to Bank Rec, I receive a message saying that the following file in use problem exists. ADS32DLL I have no programs open
#56525 - 02/21/18 02:10 PM Re: Can not install Bank Rec update [Re: corishuey]
Hello:
Is Adagio is used by anyone else other than you? if so, do those users have Adagio open? In order to install Adagio, all users must have closed all of their modules. You can tell by opening a module and selecting Help | Active Users to see who has Adagio running.
There are occasions when the user counting mechanism gets out of synch and thinks there is someone still logged in. In that case, the simplest solution is to reboot the server (when possible).
#56528 - 02/22/18 08:05 AM Re: Can not install Bank Rec update [Re: Bruce Gardner]
FinanceMFN Offline
Adagio Groupie
Loc: Ontario Canada
(69.71.79.232)
Received notice yesterday of Service pack update, which I did this morning. Would not "run" as other updates did, so ended up saving it to desktop and then downloaded no problem. Once downloaded I am now no longer able to open any other modules other than the GL.
BR gives me "Error External exception E06D7363 occurred when attempting to check existence of A/P global", while the other modules reference the E06D7363.
Can I revert to last Service pack?
#56530 - 02/22/18 09:42 AM Re: Can not install Bank Rec update [Re: FinanceMFN]
FinanceMFN Offline
Adagio Groupie
Loc: Ontario Canada
(69.71.79.232)
Re-checked all the updates and found I had missed a service pack update for AP the end of Jan/18 ... Totally my fault - was in panic mode here as we head into Y/E.
All is now working okay here!
Shirley
#56532 - 02/22/18 10:22 AM Re: Can not install Bank Rec update [Re: FinanceMFN]
Hi Shirley,
Interestingly, I got this message two nights ago and resolved it in a panic without much thought as I was preparing for a presentation. I wrote off the problem to the fact that my laptop install of Adagio is not necessarily "pristine".
In any event, installing the AP Service Pack will resolve the error which was caused by an incorrect product build.
Thanks for bringing this to our attention, and we're sorry for the inconvenience.
At the moment the download of the BankRec Service Pack is frozen while we correct the problem.
#56535 - 02/22/18 01:43 PM Re: Can not install Bank Rec update [Re: Retired_Guy]
FinanceMFN Offline
Adagio Groupie
Loc: Ontario Canada
(69.71.79.232)
Well, Andrew....it did solve "that" problem, as I'm able to open all the modules and work in them, but now when I go to Bank Rec, I cannot select a Vendor from the list as it is not accessible. So at a stand still yet again, as I cannot access my AP from the BR.
anything else I can try?
#56536 - 02/22/18 01:47 PM Re: Can not install Bank Rec update [Re: FinanceMFN]
FinanceMFN Offline
Adagio Groupie
Loc: Ontario Canada
(69.71.79.232)
One other note, just tried to print cheques and the invoices do not show up to select for vendors :-(
Normally I wait two or more weeks before I upgrade, except this time. Wishing I had waited.
#56537 - 02/22/18 03:03 PM Re: Can not install Bank Rec update [Re: FinanceMFN]
Re-download and re-install the BankRec Service Pack. The problem has been fixed.
0 registered (), 100 Guests and 2 Spiders online.
1874 Members
14555 Topics
