Loc: British Columbia, Canada
Is there a place to turn the sound off when selecting Vendors that are on hold? I understand the usefulness but I use a lot of hold vendors and every time I select one of them a get the alert sound and then again when I go to enter anything
I thought about the "Mute" button too but ...
You may be right in the other part of the answer. I use the Hold feature to stop payments from being generated to vendors that I pay by EFT etc. Maybe there's a better way.
Do you issue payments using a Manual Check batch or System Check run? Do you pay your EFT Vendors from Adagio (using Telpay or Adagio's EFT module) or do you go online and pay them. then record the payments in Adagio?
I issue cheques to my non-Hold vendors by way of system cheques once or twice a month. I pay my EFT (Hold) vendors and then record the payments in a manual cheque batch.
To prevent inadvertently paying the EFT Vendors in a System Check run, assign one of 2 Report Groups to each Vendor: "CHQ" or "EFT". Then on the System Check run screen use "CHQ" for the Report Group starting and ending values.
