#56127 - 01/27/18 12:38 PM
Re: Payables 9.3A (171027) default Acct/Dept
[Re: Steve Schwartz]
Hi Steve,
How are they entering the GL Account? Are they typing it in or popping the Finder and selecting it?
Everywhere in Adagio where you enter a GL account during transaction entry, the department is pre-populated with the department from the Finder. All the text is selected, so if you type anything then the text is replaced.
Having a warning when "an unintended" department is entered, requires a connection to the cosmic consciousness.
If an account-department pair exists, then presumably that's a valid expense distribution (although it may not be correct for the invoice at hand). Invalid account-department pairs should be marked Inactive in Ledger to prevent selection. Vendors should have default account-department pairs on their record.
Changing the way this works would result in screams of anguish from those used to this program operation. This means if we change the operation, it has to be controlled by a User Preference, which means changing every transaction entry dialog in Adagio to check the preference.
We have batches and batch listings in Adagio to allow people to easily check their work. The batch listing includes a GL account summary. Does it need to include a department summary too?
#56132 - 01/27/18 04:57 PM
Just so that I am clear on the request, you'd like us to add an option under Company Profile | Batch options under "Validate ledger account", labelled "Force department selection", which would force the user to enter both the account and department as separate operations, even if they selected the "correct" (or at last a valid) account-department from the Finder when entering the account number field.
The option, being in the company profile, would be set on a company by company (not user by user).
#56134 - 01/28/18 10:54 PM
Support:
I understand what Steve means. While some users like that Adagio tries to help by loading the first matching Department code (especially in situations with very few Departments), others would prefer a blank Department which means the user has to stop, think and select the correct Department.
One of my clients agrees with Steve's secondary request: The ability to allow a blank Department code on the Vendor master record. This would be used in situations where the GL Account can be assigned to the Vendor with accuracy but the Department can vary.
As Support stated, this is not currently possible. However this client is a relatively recent convert from ACCPAC Plus. That product didn’t do as much checking as Adagio and therefore they deliberately have a number of long-time Vendors with blank Department codes.
But that request brings up a related request. They have had a few transactions get to the GL with missing Department codes. The cause is (1) the long-term Vendor does not have a Department assigned and (2) the user is using the mouse rather than the keyboard to skip the GL Account and Department fields and go directly to the amount field. The request is that the application verifies the Account and Department when the detail form closes, not only when exiting from the Department field.
0 registered (),
198
Guests and
2
Spiders online. |
14666 Topics
