#54433 - 07/20/17 05:39 PM XConsole Shut Down was cancelled
A user left OE and IC open and XConsole was suppose to shut them down, but it didn't work. Instead there was an error on the user's computer that said, "XConsole Shut Down was cancelled". How and why did this happen? How do I get XConsole to shut down Adagio programs that are left open in the future?
#54580 - 08/08/17 02:57 PM Re: XConsole Shut Down was cancelled [Re: SusanTennier]
Hello Susan,
Sorry for the delay in responding.
There isn't enough information to answer the question. What are the versions being used?
If there was an unacknowledged message on the screen, Console may not have been able to shutdown.
We have also had this reported in an older Console when data was being accessed by a program being run from a local drive instead of the network drive.
#55004 - 09/19/17 09:49 AM Re: XConsole Shut Down was cancelled [Re: Softrak Support]
doug Offline
Doug Parrington
Loc: Winnipeg
I get the same "XConsole Shut Down was cancelled" as well. I am running XConsole from a workstation. Adagio data files are on server. Any suggestions appreciated.
Here are the versions
Console 9.2B (170323)
GridView 9.2B (160504)
DataCare 9.2A (150916)
FX 9.2A (160517)
Inventory 9.2A (170608)
Ledger 9.3A (170625)
ODBC 9.2A (151027)
OrderEntry 9.2A (160707)
Payables 9.3A (170623)
PurchaseOrders 9.3A (170821)
Receivables 9.2A (170711)
SalesAnalysis 9.2A (170904)
SalesCQ 9.2A (170221)
Doug Parrington
#55369 - 10/19/17 04:48 PM Re: XConsole Shut Down was cancelled [Re: doug]
Hi Softrak Support,
In your response above you said, "If there was an unacknowledged message on the screen, Console may not have been able to shutdown." The whole idea of xconsole I thought was to shut down Adagio programs that were inadvertently left open so that DataCare can have exclusive access to the dataset. Are you saying that unless someone acknowledges the warning message that I have set to 5 minutes before shut down, that it won't shut the program down?
#55375 - 10/20/17 10:17 AM Re: XConsole Shut Down was cancelled [Re: SusanTennier]
Hi Susan,
Support is mistaken. An unacknowledged message will be closed by xConsole and the application terminated.
For xConsole to work correctly, it is important that NO ONE accesses the network data from an Adagio module running on a local drive. Please make sure that all your shortcuts point to the same Softrak Folder on your network to launch Adagio.
Could you list the versions you are running please? Using \Softrak\System\CHKSYS.EXE | List Versions is probably the fastest way of building the list.
Also, was the shutdown a scheduled or one-time shutdown request (I'm assuming it is a scheduled request).
Edited by Andrew Bates (10/20/17 10:20 AM)
Edit Reason: Request for version info.
#55381 - 10/20/17 10:44 AM Re: XConsole Shut Down was cancelled [Re: Retired_Guy]
Thanks for your reply. I can confirm that NO ONE accesses the network data from and Adagio module running on a local drive. All of our users are running Adagio on the server via RDP.
XConsole is scheduled every Monday - Friday evening (screen shot attached). However, when a user leaves Adagio open, XConsole fails with a message "XConsole Shut Down was cancelled". As a result, DataCare aborts.
Here are our versions at the moment:
All the following are based on the Adagio List Version [170904].
The following Adagio programs are NOT Current:
Ledger 9.2B (170320) [must be version: 9.3A (170625)]
Payables 9.2B (170130) [must be version: 9.3A (170623)]
PurchaseOrders 9.2B (170425) [must be version: 9.3A (170821)]
Receivables 9.2A (161013) [must be version: 9.2A (170711)]
The following Adagio programs are Current:
ePrint 9.2A (150919)
MultiCurrency 9.2B (161128)
OrderEntry 9.2A (170628) HF
The following Adagio programs are not installed (*):
BankRec 9.2A (170720)
FX 9.2A (160517)
Invoices 9.2A (170830)
JobCost 9.2A (160126)
ODBC 9.2A (151027)
Addon: BoM 9.2A (150429)
Addon: ChartView 9.2B (160506)
Addon: EFT 9.3A (170624)
Addon: GridViewRW 9.2B (160505)
Addon: ODBCRW 9.2A (151028)
Addon: RMA 9.2A (160112)
XConsole Settings2.png (168 downloads)
#55386 - 10/20/17 11:50 AM Re: XConsole Shut Down was cancelled [Re: SusanTennier]
Hi Susan,
Your quoted message does not appear in any of the code. The closest we can find is:
Quote:
"The Scheduled Shutdown has been Cancelled!"
Is this the message you are seeing?
5:25pm is shortly after the end of your day. Do you go into xConsole and adjust the shut down time if you are still working at that time?
Edited by Andrew Bates (10/20/17 11:57 AM)
Edit Reason: Added ?? about editing schedule.
#55387 - 10/20/17 11:57 AM Re: XConsole Shut Down was cancelled [Re: Retired_Guy]
Hmm I took a screenshot last night but it's on my computer at home. I'll post it here tonight.
I intentionally left IC open a couple of nights ago to see what it would do and it worked fine. So it's not a problem consistently. When it is a problem, I see that pop up about the shutdown being cancelled.
#55389 - 10/20/17 01:18 PM Re: XConsole Shut Down was cancelled [Re: doug]
Hi Doug,
Is this a scheduled shutdown or an "on demand" one.
#55393 - 10/20/17 05:35 PM Re: XConsole Shut Down was cancelled [Re: Retired_Guy]
See attached screenshot.
Screen Shot 2017-10-19 at 6.58.36 PM.png (175 downloads)
1 registered (Bruce Gardner), 587 Guests and 4 Spiders online.
14578 Topics
