#54640 - 08/14/17 02:04 PM
PDF Printer Adagio V2PDF not found
Loc: Peterborough, ON
I get this error when trying to eprint posting journals in AR and BankRec. I just updated all modules, so we are current in all versions, including the AP hotfix for 9.3A. I don't have the AdagioV2PDF printer in my devices and printers, just the AdagioPDF one. How do I get that printer? I also have Adobe Acrobat, so I do have Adobe PDF and I have ABS PDF Driver v400 - is that the V2PDF? Should/Can I just rename that one? I tried running Softrak/system/AdagioPDF/adagioV2pdf.exe, but had no change. Operating system is Windows 7 Pro 64 bit.
Barb
#54650 - 08/15/17 08:37 AM
Re: PDF Printer Adagio V2PDF not found
[Re: Softrak Support]
I'm the only user on our network having this problem - two others are eprinting in Payables, Receivables and BankRec just fine.
Below are the results of GetInfo:
Adagio Workstation Information [as of 8/15/17 11:18:51 AM] Run from [K:\Softrak]
User: [bdumble] Logged into [\\YDC] as Admin. [False] with UAC Enabled [1] on Computer Name [YWCAPH-DT6] Windows Version: [6.1.7601] Processor: [Intel64 Family 6 Model 94 Stepping 3, GenuineIntel]
Adagio Mapped drive: [K:]; UNC: [\\2k8server\accdata];
=========================================================================== Adagio Payables 9.3A (170718) === Company: [YWCA of Peterborough] Wkst Version OK: [True]; Registry [20140733]; {must be >=} Main [20140733] Report Tables Status: Result is OK: [True]; {Is Eval. version: [False]} Report Tables drive: CU Registry [K:\]; CU UNC []; LM Registry []; LM UNC [] Resources: Flags [CIXM9wR8D] Web storage Exe: [] PDF Version 8 must update: [False]; Nova8 File Ver: [8.7.943.0] must be >= SysComponents: [8.7.943.0] Crystal Scheme OK: [True]; Reg. [13.0.16] must be >= Min. [13.0.16]; dotNET Scheme OK: [True]; Reg. [460805] must be >= Min. [378389]; ODBC Component Path: [K:\Softrak\ODBCV2\AdagioODBCv2.dll] ODBC Component Scheme OK: [True]; File. [2.1.8.189] must be >= Min. [2.1.8.189]; System Files: Components: [INST PRGR CR_13.0.16 DN_378389 OD_2.1.8.189 PDF_8.7.943.0] No QRW Files. ----- Registry Trace: ----- HK_LMx64: [Software\Softland\novaPDF 8] {Default:}; exists: [True];+Opened; . .Key: [DriverPath] exists: [True] Value: [C:\Program Files\Softland\novaPDF 8\Driver] HK_LM: [SOFTWARE\SAP BusinessObjects\Crystal Reports for .NET Framework 4.0\Crystal Reports\] {Default:}; exists: [True];+Opened; . .Key: [CRRuntime32Version] exists: [True] Value: [13.0.16] HK_LM: [SOFTWARE\Microsoft\NET Framework Setup\NDP\v4\Full] {Default:0}; exists: [True];+Opened; . .Key: [Release] exists: [True] Integer Value: [460805] HK_LM: [Software\ODBC\ODBC.INI\Adagio Data Source] {Default:}; exists: [True];+Opened; . .Key: [Driver] exists: [True] Value: [K:\Softrak\ODBCV2\AdagioODBCv2.dll] ***** Adagio Payables STATUS: OK - NO Workstation Update Needed. *****
Note 2k8server is our old server - don't know why some things still point to it, but it's been over 6 months and things are running fine with a small exception like this printing issue occasionally.
I'm more familiar with networks, mapping and IT in general than most accounting users, so I try to do things myself as much as I can to save money for our charity. So if there see anything problematic here or any other suggestions please let me know.
Barb
#54653 - 08/15/17 09:16 AM
[Re: bd]
Hi, Barb,
Your Adagio consultant would probably need an Adagio system snapshot to troubleshoot the incorrect server references.
Regarding the AdagioV2PDF printer driver, all indications are that it is installed. Perhaps it was accidentally deleted or Windows has played one of its tricks.
In any event, I would look at your Control Panel, Programs and Features and uninstall 'only' the following 4 components. Only these 4, relate to the AdagioV2PDF:
novaPDF 8 Printer Driver Softland novaPDF 8 SDK COM (x64) Softland novaPDF 8 SDK COM (x86) Softland Adagio Accounting PDF Printer Softland
In the Search box in the upper right of the Programs & Features, you can type novaPDF to find the first 3 ('do not' uninstall the PDF 7.4 printer) and then PDF to find the Adagio Accounting PDF Printer. After they are uninstalled, drill down to the Softrak\System\AdagioPDF folder on the server and run the AdagioV2PDF.exe again. Only run it once. After, check for the existence of the AdagioV2PDF printer on your w/s and, if necessary, in the Control Panel again.
Edited by Softrak Support (08/15/17 09:24 AM)
Regards, Softrak Tech Support
#54655 - 08/15/17 09:27 AM
Just to clarify do I only uninstall NovaPDF 8 Printer Driver
or the 4 Softland ones: novaPDF (NovaPDF 7.4 printer) NovaPDF 8 Printer Driver NovaPDF 8 SDK COM (x64) NovaPDF 8 SDK COM (x86)
Sorry I didn't see your full post for some reason - will uninstall the 4 you said and not the 7.4 one - I wondered about that.
Edited by bd (08/15/17 09:29 AM)
Barb
#54657 - 08/15/17 09:50 AM
It worked. I have administrator rights so I guess that's why I didn't have a problem without that last bit.
Thank you!
Barb
#58028 - 07/11/18 05:20 PM
[Re: bd]
Adagio Ace
I followed the instruction but It did not work for me.
2 registered (Warren Karges, 1 invisible),
156
Guests and
2
Spiders online. |
1865 Members
14492 Topics
