Page 1 of 3 1 2 3 >
#53980 - 06/14/17 10:59 AM Adagio print error
JohnDilworth Offline
Loc: Orlando, FL USA
I get the following error when trying to print in Adagio. I tried rebooting, then re-installing Adagio and still get the same error. Any ideas what to do?
Logon failed.
Details: [Database vendor code 160]
Error in file .......
Unable to connect: incorrect log on parameters
#53981 - 06/14/17 11:19 AM Re: Adagio print error [Re: JohnDilworth]
Adagio module? Version? Report?
#53982 - 06/14/17 11:24 AM Re: Adagio print error [Re: Retired_Guy]
It's happening with all modules and all reports.
I'm using AP 9.2B, GL 9.2 B, etc.
#53983 - 06/14/17 11:43 AM Re: Adagio print error [Re: JohnDilworth]
Hi John,
The 'error 160' indicates that the Crystal Runtime is not able to make an ODBC connection. Adagio programs at version 9.2A or later use these components for reporting, rather than a different report table process in Adagio versions older than 9.2A.
One specific report - the User Preferences listing - does not use an ODBC connection, so if you can preview/print this report with no error, that means the Crystal Runtime install is OK, and the issue is with the ODBC part.
Some versions of Windows do not pre-install ODBC files MSVCR110.DLL and MSVCP110.DLL in the C:\Windows\SYSWOW64 directory. Recent versions of Adagio will install these, just in case Windows doesn't have them, and also save a copy to the \Softrak\System\Win32 and \sys64 directories in case you need to copy them in manually - say if the install user didn't have the correct rights.
In the \Softrak\System directory is also a utility OCSTEST.EXE to test the ODBC Connection String, with a help document ConnectionTesterInfo.PDF to describe how this works.
#53984 - 06/14/17 12:36 PM Re: Adagio print error [Re: Softrak Support]
Sorry but I haven't been able to solve the problem yet.
The User Preferences listing runs OK
so that means the Crystal Runtime install is OK, and the issue is with the ODBC part.
I checked that the ODBC files MSVCR110.DLL and MSVCP110.DLL are in the C:\Windows\SYSWOW64 directory.
I ran OCSTEST.EXE to test the ODBC Connection String, using a sample string as described in the help document. I get the message: Unable to create connection!
FYI, here is the actual connection string that I tested it with:
DRIVER=AdagioDataSourceDriver;
DBQ=C:\SOFTRAK\Receivables\SAMDATA SAM;
DESCRIPTION=Adagio ODBC v2 Driver;
DBDIRECTORY=C:\SOFTRAK\Receivables\SAMDATA;
COLUMNS=COMMON;
DBFILTER=AR9*;
DBSELELECTOR=SAM;
NAMES=LONG;
TABLESALL=FALSE;
USERID=SYS;
PASSWORD=SYS;
RAWPASSWORD=1;
#53986 - 06/14/17 01:03 PM Re: Adagio print error [Re: JohnDilworth]
John
Workstation and server o/s?
#53987 - 06/14/17 01:13 PM Re: Adagio print error [Re: Douglas Dickie]
I'm running it on my laptop only, using the NFR versions of Adagio. OS is Windows 7 Professional Service Pack 1
#53989 - 06/14/17 02:30 PM Re: Adagio print error [Re: JohnDilworth]
I would reinstall Crystal manually. Current version is 13.0.16.1954. Is that the one you have installed?
The installer is System\CR_InstallCommon
Edited by Patricia B. (06/14/17 02:32 PM)
#53991 - 06/14/17 02:59 PM Re: Adagio print error [Re: Patricia B.]
I found the msi file in the folder you mentioned. Tried to reinstall but it said it could not find something. The only option was to quit.
#53992 - 06/14/17 03:34 PM Re: Adagio print error [Re: JohnDilworth]
Do you have the User Account Control disabled (bar at the bottom)? Disable it, restart the computer and try again.
Page 1 of 3 1 2 3 >
0 registered (), 115 Guests and 1 Spider online.
1865 Members
14487 Topics
