#41920 - 06/11/14 06:15 AM
SalesCQ - Copy Open Quotes to History
Loc: Concord, On
Hi
I was trying to do a little housekeeping yesterday and wanted to move open quotes older than Jan.1, 2014 to history. I used Copy Quotes from the maintenance menu and entered a date range. The first two times I received 0 moved messages. The third time I received a 135 Moved message. Unfortunately there were over seven hundred quotes to move (no comments please). All the ones that got copied over were from 2014. There also was no transfer date attached to the quote either. I've attached a picture of my selection criteria in case I missed something. All quotes are open.
Mike Smith Viktorian Sheet Metal Mfg Inc
#41930 - 06/11/14 11:46 AM
Re: SalesCQ - Copy Open Quotes to History
[Re: Steve Schwartz]
Loc: Concord, On
Thanks Steve
It's tedious but it works. But when doing it this way, there is no transfer date assigned to the copied quote. I also don't understand why a quote has to be 'deleted' when its moved. Doesn't it make more sense to delete it automatically when its moved to history? Why would anyone want the quote in two places at the same time?
Mike
#53060 - 03/19/17 09:00 PM
Adagio Conductor
Changes have been made to the seletion process for maintenance functions (print/delete/copy). Specifically, the logic for the check boxes. I'm sure it's documented.
#53061 - 03/20/17 05:30 AM
[Re: Bob Wisener]
Ah, I see the change in the Help section. Whereas it used to say:
To be copied, a quote must meet all the conditions of Transferred, Expired, Printed and Rejected you select. For example, if you select Transferred and Printed, only transferred quotes that have also been printed will be copied.
now it says:
To be copied, a quote must meet one of the conditions of Transferred, Expired, Printed and Rejected enabled. The Quote types enabled are or conditions, eg. Transferred or Printed if both are enabled
I think that change should be pointed out in the Release Notes. It's an important one.
#53062 - 03/20/17 08:08 AM
Adagio Conductor
It should also be pointed out that if none of those 4 options (Transferred, Expired, Printed and Rejected) are chosen, the quote is selected. That's assuming the quote satisfies the other ranges. That should give you better results.
#53067 - 03/20/17 10:25 AM
[Re: Douglas Dickie]
Adagio Conductor
Those changes are new to CQ92A. It wouldn't have helped the prior version.
0 registered (),
149
Guests and
Spider online. |
