Good morning,
I copied my operations statement report and renamed it. I want to re-calculate revenues and expenses and budget each month and year to date according to the number of performance dates for each period. This will hopefully provide me with a very rough KPI.
Everything went very well for the first hour or two and I was an accounting genius. Now I can't get things to work and I am an unhappy semi-genius.
For each accounting period I am holding the number of Performance Dates constant. So, for instance, in one of the cells I've typed =ADGET("GLDATA.Y",$B122)/$I$9 It's a lovely formula and I'm so fond of it I would like to copy it down the balance of the column EXCEPT Adagio tells me I can't because that cell is a generated number EVEN THOUGH it accepted the formula and its repetition earlier.
To add insult to injury, at random intervals the program shuts down for no apparent reason and I lose everything I've just manually entered. Not being unteachable, I started to save after every third or fourth formula creation. Imagine my feelings when I discovered at the end of the day that that wasn't working. I have to hit "Save As" and over-write the existing file before my changes are actually saved.
I can't even edit the existing formula, I have to type it in from scratch each time.
So if you have words of wisdom or direction, I'd love to hear them. I feel that the solution must be user error because no one could create such a goofy system on purpose.
Cheers,
Candace
