#47384 - 09/27/15 02:17 PM FR templates
JeanB Offline
Loc: Kelowna, BC
I'm trying to open the SuperSpec90 template (which I have opened many times before) but I'm getting the error "Unexpected file format" and it won't open, and neither will any of the other templates. File type is FST...any ideas why it won't open?
Jean
#47385 - 09/27/15 02:44 PM Re: FR templates [Re: JeanB]
What version of Ledger?
#47386 - 09/27/15 02:50 PM Re: FR templates [Re: Retired_Guy]
JeanB Offline
Loc: Kelowna, BC
9.2A (150903)
#47387 - 09/27/15 02:57 PM Re: FR templates [Re: JeanB]
Try using File | Import workbook from softrak\Ledger.
#47388 - 09/27/15 03:16 PM Re: FR templates [Re: Retired_Guy]
JeanB Offline
Loc: Kelowna, BC
Thanks Andrew - I found the file and was able to import it. Weird that it won't open as a template though.
#47390 - 09/27/15 08:46 PM Re: FR templates [Re: JeanB]
Fails for me too. I'll ask someone to check it out. Could be an install problem.
#47392 - 09/28/15 10:05 AM Re: FR templates [Re: Retired_Guy]
JeanB Offline
Loc: Kelowna, BC
I'm always glad when it's not just me...thanks Andrew!
(...although I'm at my other job this morning and the templates open just fine...must be an issue with my install over at my other place)
Edited by JeanB (09/28/15 10:18 AM)
#47394 - 09/28/15 11:18 AM Re: FR templates [Re: JeanB]
Hi Jean,
What version of Ledger at your "other job"?
#47395 - 09/28/15 12:06 PM Re: FR templates [Re: Retired_Guy]
Hi, Jean/Andrew,
It seems that the templates that went out with the (150903) SP were for a newer version of the FR.
Using the File | Import Workbook function and importing the GL!SuperSpec90.SAM statement from sample data, or copying the GL!SuperSpec90.SAM statement from sample data and renaming its extension both work.
I've reported this to R&D for you.
#47396 - 09/28/15 12:33 PM Re: FR templates [Re: Softrak Support]
Hi, Jean,
You can access the FR templates installed prior to the SP(150903) here.
They can be unzipped and replace the existing files in your Softrak\FSDesigner\Templates folder.
This affects GL9.2A(150903) only. Earlier releases do not experience the issue.
0 registered (), 263 Guests and 2 Spiders online.
14667 Topics
