#45917 - 05/28/15 11:13 PM GridView 9.2A MDB Direct
MarlonMF Offline
Loc: Los Angeles, CA
When I click on the DB button with Add (actually any option) as the option and I pick the MS Access Database file (.accdb), it gives me an error "Failed to connect to MDBDirect.".
Do I need to add a parameter on the GridView shortcut to be able to use MDBDirect?
I have GridView 9.2A (140829), MS Access 2013 32-bit.
Marlon
#45921 - 05/29/15 08:37 AM Re: GridView 9.2A MDB Direct [Re: MarlonMF]
Usually you need to define a DSN to the access database. Have you done that?
#45940 - 05/29/15 04:22 PM Re: GridView 9.2A MDB Direct [Re: Retired_Guy]
MarlonMF Offline
Hello Andrew,
Yes, I've define one dsn specifically for AO80 tables but I was exporting records from AR92 tables which was the problem.
Thank you.
Marlon
0 registered (), 161 Guests and 2 Spiders online.
14672 Topics
