#44994 - 03/18/15 11:04 AM Sale Items
Is there a way to create a filter for IC Items to show which items are currently on sale? We would like to use the criteria, "Sale End Date" "Greater than" "Today". However, "Today" is not an option. We have to select an actual date from the calendar.
We use IC Item Inquiry to quote customers prices all day long, but we can't recognize whether an item is on sale unless we look at the "Sale price", "Sale starts" and "Sale ends" fields every single time we look up an item and determine if those dates are current. This is far too tedious. The only workaround we know is to enter the item on an order in Order Entry, however, this is not practical either.
Is there any way we can identify the current sale items with a filter?
#44995 - 03/18/15 11:12 AM Re: Sale Items [Re: SusanTennier]
Hi Susan,
What version of Adagio Inventory do you have installed?
With the service pack 2015.02.24 installed - and perhaps earlier versions as well - you can create a filter with "Sale End Date" - "Floating date range" - "After today". The inclusion of After today (and Before today) as floating date range choices is fairly recent across Adagio programs. These choices are at the end of the floating date range list.
You probably will also want to include in your filter a second criteria to check that "Sale Start Date" - "Floating date range" - "Before today" to ensure that Today is within the sale date range, rather than being prior to the entire range.
#44998 - 03/18/15 11:27 AM Re: Sale Items [Re: Softrak Support]
We are running 8.1E (150224). It worked thanks! We used "Floating date range" "after today" like you suggested. It would be even better if we could do "Floating date range" "today or after today", but this is a great improvement.
#45001 - 03/18/15 11:45 AM Re: Sale Items [Re: SusanTennier]
Glad that works!
You could also put 2 criteria into your filter to get what you are looking for:
"Sale End Date" - "Floating date range" - "After today" OR
"Sale End Date" - "Floating date range" - "Today"
#45003 - 03/18/15 12:00 PM Re: Sale Items [Re: Softrak Support]
We went with:
Sale Start Date - Floating date range - Today - OR
Sale Start Date - Floating date range - Before today - AND
Sale End Date - Floating date range - Today - OR
Sale End Date - Floating date range - After today
Now our staff can see SALE items in RED. This is excellent. Thanks!!
#45017 - 03/19/15 10:58 AM Re: Sale Items [Re: SusanTennier]
This isn't actually working right. It is adding items to this filter with a Sale Start Date of April 1, 2015 and a Sale End Date of May 15, 2015. What am I doing wrong?
#45019 - 03/19/15 11:15 AM Re: Sale Items [Re: SusanTennier]
Choose:
Code:
Sale Start Date    Floating Date Range     Before today      AND
Sale End Date      Floating Date Range     After today       OR
Sale End Date      Floating Date Range     Today
and see if that selects the records you expect.
#45020 - 03/19/15 11:28 AM Re: Sale Items [Re: Retired_Guy]
Hi Susan,
I suspect the ANDs and ORs are not overlapping with the required logic.
I believe this one works, using slightly different logic to remove OR out of the process:
Code:
Sale Start Date - Not Equal To        - blank            AND NOT
Sale Start Date - Floating Date Range - After Today      AND NOT
Sale End Date   - Floating Date Range - Before Today
This ensures that there is a sale date range entered and is before or equal to today, and that the end date is after or equal to today.
#45022 - 03/19/15 12:31 PM Re: Sale Items [Re: Softrak Support]
Thanks, it turns out I had to clear all my filters back to standard and start fresh applying them again. It's good now. Sorry for the confusion!
#45024 - 03/19/15 12:37 PM Re: Sale Items [Re: SusanTennier]
I like Support's Filter better. It's easier to read.
0 registered (), 86 Guests and 2 Spiders online.
1865 Members
14512 Topics
27 28 29 30 31
