#43865 - 12/12/14 02:18 PM
printing in G/L
Loc: Alberta
After installing the ledger upgrade, we can only print single-sided
We will print double sided and even double sided, 2 pages per side when needed, simply to conserve paper, so 60 pages of print uses only 15 peices of paper. I printed a large batch, and changed the settings to double side, 2 pages per side, but the printout still came out as single sided.
But when printing to the same printer seconds later from the a/p, a/r or invoicing we can still print double sided and double sided, 2 pages per side.
#43869 - 12/13/14 10:08 AM
Re: printing in G/L
[Re: Softrak Support]
Loc: Alberta
that's what I've done. I'll wait for the fix.
#43889 - 12/16/14 08:07 AM
Re: printing in G/L
[Re: Marc]
Loc: B.C.
I have a client with the same issue. GL9.2A GL reports fail to print double-sided on an HP laserjet P2055. Just wondering about the progress on this item? Requiring the extra steps of printing reports through the PDF option works as a short term solution.
JS
#45340 - 04/15/15 02:23 PM
Re: printing in G/L
Loc: Alberta
Hi again Double sided printing seems to work, but if I try double-sided, 2 per page, it will only print double-sided 1 per page. Regards
#45344 - 04/15/15 04:06 PM
Re: printing in G/L
[Re: Marc]
Where are you setting "double sided, 2 per page"? What make/model of printer are you using?
#45429 - 04/23/15 08:14 AM
Re: printing in G/L
[Re: Retired_Guy]
Loc: Alberta
Lexmark universal v2 XL
We ran the Payables upgrade. Now Payables will not recognize the manual paper tray on that printer. This will be a problem, because we have pre-printed, numbered cheque stock that we use. We normally print them using the manual paper feed tray, so the cheque numbers are assigned properly (i.e. the first cheque on the top of the pile is #1, and pulled off first, then #2, #3, etc. etc.)
The paper drawer would print them using the bottom cheque first (i.e. if we put in 100 cheques, it would print #100 first, then #99, #98, etc, but the program would think it's printing #1, #2, #3, etc).
#45430 - 04/23/15 08:16 AM
Re: printing in G/L
[Re: Marc]
Loc: Alberta
Sorry - its a Lexmark M1145 And yes, I had the setting done at double-sided, 2 pages per side
14576 Topics
