#4297 - 09/16/04 06:59 PM Department Range on Financials
Kate Spontak Offline
Loc: New Jersey
Client wanted to add another department range to his financial statements. He was following the same procedure as before but said the "OK" button was not lit up, and he could not TAB to it.
GL is version 8.0, (040618)
I edited GLDTREE to create the groups he needed and sent it to him, but I wondered why the function is not working.
#4298 - 09/17/04 11:50 AM Re: Department Range on Financials
Hi Kate,
We're aware of an issue with adding new Department Masks in the current Financial Reporter, but not with Ranges. If it's ranges that is the issue, please let us know.
The issue with Masks is that if you create one that starts with question marks (ie ??00), then the OK button is disabled. You can workaround this by doing one that doesn't start with question marks (which works) then do the one(s) you want. Delete the other one if not necessary.
This will be addressed in a future service pack.
#4299 - 09/22/04 10:00 AM Re: Department Range on Financials
Loc: New Jersey
According to the client, no matter what he put in as a mask, the OK button was not available.
#4300 - 09/22/04 10:28 AM Re: Department Range on Financials
Ralph Allan Offline
Kate:
Just a thought . . . when you sent the new GLDTREE files to your client, were they on a CD?
If so the read-only attibute would have been set and retained when they were copied to the client's system.
#4301 - 09/22/04 11:10 AM Re: Department Range on Financials
Don Wise Offline
Adagio Expert
Loc: Ottawa
I experienced the same behaviour but randomly. Never had a chance to try to figure it out but it would also occur in the sample database as well where I have never added any departments or masks before. It was just easier at the time to create the masks with a text editor.
I was always able to edit or delete any masks that had already been created.
While we are mentioning Departmental masks - Is there a formula that allows us to print the mask's description on the financial sheet.
Don Wise
Westboro
#4302 - 09/22/04 11:52 AM Re: Department Range on Financials
Hi Don Wise,
=DEPARTMENT(0)
returns the currently selected department's name.
#4303 - 09/22/04 12:03 PM Re: Department Range on Financials
Don Wise Offline
Adagio Expert
Loc: Ottawa
Andrew;
Sorry I should have been more specific. In the sample data deptDemo.sam, if you replace the department 100 with a mask such as ?00 or a range, can you get their descriptions to print similar to the way the department descriptions print.
Don Wise
Westboro
#4304 - 09/22/04 01:27 PM Re: Department Range on Financials
Hi Don,
Not that I can think of, off the top of my head. It's a good suggestion though. I'll add it to the list.
The problem is that the masks and ranges are stored in a different file from the deparmtment numbers and descriptions. Hmmm - Have you tried adding the masks to the Ledger Department file?
#4305 - 09/23/04 06:37 PM Re: Department Range on Financials
Don Wise Offline
Adagio Expert
Loc: Ottawa
Kate;
I think I have found what you client may be running into. When creating a departmental mask, if you highlite the word "Departments" in the department view window and right mouse click, an option is available to Create Departmental Mask. You can create the mask and give it a description but the OK button will not activate. If you highlite an existing department in the department view window, then you can create the mask you want and the OK button will activate. If you highlite an existing mask in the department view window, you can only edit or delete the mask you highlited. It seems that you must create one department before before you create a mask.
Note that the help manual says otherwise, but this the only way that I could get it to activate the OK button on any Adagio station I have tried.
Don Wise
Westboro
#4306 - 09/23/04 09:21 PM Re: Department Range on Financials
Loc: New Jersey
Thanks for the research, Don. I passed it along to the client to test.
In my GL, with "Departments" highlighted, I can create a mask and the "OK" button works. But I cannot create a mask in the form 201:215, because only 6 characters are allowed, although I was able to do this before in my client's data.
I have the same options to "create" when one department is highlighted and "edit" or "Delete" when a departmental mask is highlighted.
When I create a mask with "201215" or "depart", it acts like a department and cannot be deleted.
I am using W2K and my client has XP Pro.
I am curious to know what operating system you use.
14617 Topics
