#41221 - 04/23/14 09:28 AM Printing one specific user
berwick Offline
Adagio Fan
Loc: BC, Canada
Hey,
Got a strange issue happening in Ledger. One specific user on the network can't print, it's not the Adagio login that is causing the issue, it's the windows user that seems to have some special settings that are causing it.
I rebuilt the user account from scratch, but the issue is still there. When you print, it goes through the motions like it will...but then nothing prints. No errors, no warnings, just no printing. If I log on any other user (windows) it prints fine.
Is there a spot somewhere in Adagio where it tracks the Windows User that is logged on and gives special settings? I already ran the setreports and chksys programs (which did fix some UNC errors, but didn't resolve the printing issue).
#41222 - 04/23/14 09:40 AM Re: Printing one specific user [Re: berwick]
Can the user print to the AdagioPDF printer?
#41223 - 04/23/14 09:57 AM Re: Printing one specific user [Re: Retired_Guy]
berwick Offline
Adagio Fan
Loc: BC, Canada
Nope, no printers. Tried local, network, Fineprint, Adagio PDF, PDF Factory pro. It acts like it's going to print, but then nothing happens. Its a very odd issue and it's only for this one specific user. I thought blowing away the users profile and making a new registry file would solve it, but Adagio seemed to remember.
Also, I should give some more information on the issue to help understand. We are in a Windows Domain Environment with users that have roaming profiles and redirected folders. We recently moved the Adagio install to a new server, and the UNC pathing issues I saw before were pointing to the old servers directories. However, all other users, on multiple systems in the same domain can use, print and work in Adagio without issue, all using the same UNC paths and network drives.
I was wondering if this specific user might be experiencing some weird Reports directory issue, because I *think* when I was troubleshooting before, it said the reports directory was overridden at some point before for that users old workstation. However, I fixed that and when I run chksys it says it's pointed properly (no errors). But maybe something along those lines?
Edited by berwick (04/23/14 10:04 AM)
#41225 - 04/23/14 10:01 AM Re: Printing one specific user [Re: berwick]
Can this user print a 'simple' report such as the Company Profile? Many reports in Adagio require temporary work files, such as the Detail Listing, Trial Balance or Posting Journals in Ledger, and I have seen workstation rights problems to the local temp directory as the cause. The Company Profile report does not use a work file, so if this report previews successfully then the problem is the user's Windows setup.
#41228 - 04/23/14 12:56 PM Re: Printing one specific user [Re: Softrak Support]
It would help to know which O/S the workstation is using.
More than likely there is a dead temp file that needs to be deleted manually. (If memory serves me correctly) In Windows XP look for c:\documents and settings\user_name\Local settings\temp. Delete the contents of this folder. Any file in use cannot be deleted and any file not is use is generally no longer required or will be recreated next time it is required, so this is a fairly safe task.
#41242 - 04/24/14 08:38 AM Re: Printing one specific user [Re: Douglas Dickie]
If it is a roaming profile, it maybe missing the Crystal Folder in the user_name\local settings\Windows or the user home folder\My Documents\Windows
#41250 - 04/24/14 12:26 PM Re: Printing one specific user [Re: Patricia B.]
berwick Offline
Adagio Fan
Loc: BC, Canada
Hey,
Thank you for the help, it did end up being something with her Application Data folder, might have been the temp thing, or the crystal reports thing. When I rebuilt the profile before, I had forgotten that the Application Data folder was redirected along with Desktop and My Documents (Which I had left alone due to the data in those folders). So although I wiped out most of the settings including the ntuser.dat files, it still had traces of the crystal reports folders and whatever else Adagio puts in there. I nuked that folder and let it rebuild and everything is working now.
0 registered (), 239 Guests and 10 Spiders online.
14576 Topics
