#40337 - 02/24/14 07:33 AM Financial Reporter - Labeling
Lulu Kauffman Offline
Loc: Maryland
QUESTION ONE:
If I have more than one GL account # referenced in column C how do I choose which Description will print when using the &ADGET statement?
Currently I have:
8220:8221-` =" "&ADGET('gldata.DESC", $C19)
This is printing the GL Description for 8221.
I'd like to print the GL Description for 8220.
QUESTION TWO:
I have the following GL accounts:
8190
8190-1,8190-2,8190-4,8190-5,8190-100
I want to lump all the accounts, EXCEPT 8190-2 on one line and I want to pick the description from account 8190. How do I write that?
Thanks!
#40343 - 02/24/14 11:23 AM Re: Financial Reporter - Labeling [Re: Lulu Kauffman]
Hi Lulu
Your questions raise more questions in my mind.
QUESTION ONE:
Normally, the account ranges are in column B, not C. What's in column B?
What I would do is insert a "hide-when-printed" column, let's call it column D. In there I would enter 8220-`. Then I would change the ADGET formula to refer to $D19, not $C19.
QUESTION TWO:
If you want to hardcode departments into the account range, how do you print out departmental reports? If you don't, then why have departments?
I would strongly suggest changing account 8190-2 to 8191-2 (or some other unused number). The main purpose for a chart of accounts is to support printing financial statements, and that is very hard to do if the same account needs to appear on multiple lines on a financial statement.
I am answering these questions without much knowledge of your situation - you might be better off bouncing your questions and my answers off of your Adagio consultant.
#40362 - 02/25/14 07:39 PM Re: Financial Reporter - Labeling [Re: Lulu Kauffman]
Hi Lulu,
Question One
To retrieve the first description in a range of accounts, rather than the last, use =ADGETF() instead of ADGET().
Question Two
Make the range
Code:
8190,8190-1,8190-4,8190-5,8190-100
and use ADGETF() to pick up the first description (or just type it into the field).
1 registered (1 invisible), 235 Guests and 1 Spider online.
14636 Topics
