I'm trying to create a document filter for receipts that will only show receipts before a certain receipt number. I've attached views of two tries that came back with no results. I tried a couple of other things such as changing filter by and adding the document type field to the filter with no results. Hoping someone can steer me in the right direction.
I don't think there's a problem with your filter, but it appears from your screenshot that your filters are disabled. Check that filters box and also click the refresh button next to the dropdown filter list. That will ensure that the filter/style has been refreshed.
You show two different versions of that filter. You certainly want to use the 'RC-' version because the document contains the 'RC-'. You could play around with a less restrictive filter like 'containing'. It's always better to start with something that shows you at least one match.
Try Chris' suggestion first. Perhaps I'm wrong about the actual content.
Edited by Bob Wisener (01/20/1412:07 PM) Edit Reason: Chris' comments
