#39936 - 01/20/14 10:56 AM Purchase Order Document Filter
MikeS Offline
Loc: Concord, On
I'm trying to create a document filter for receipts that will only show receipts before a certain receipt number. I've attached views of two tries that came back with no results. I tried a couple of other things such as changing filter by and adding the document type field to the filter with no results. Hoping someone can steer me in the right direction.
Receipts A.png (198 downloads)
Receipts B.png (160 downloads)
#39938 - 01/20/14 11:34 AM Re: Purchase Order Document Filter [Re: MikeS]
Bob Wisener Offline
Adagio Conductor
I don't think there's a problem with your filter, but it appears from your screenshot that your filters are disabled. Check that filters box and also click the refresh button next to the dropdown filter list. That will ensure that the filter/style has been refreshed.
Bob Wisener
Dakota Software
#39940 - 01/20/14 11:51 AM Re: Purchase Order Document Filter [Re: Bob Wisener]
MikeS Offline
Loc: Concord, On
Sorry Bob
I disabled the filter to show the list I was filtering. When I had it enabled, and pressed the refresh button, I got zero results.
Mike
#39941 - 01/20/14 12:03 PM Re: Purchase Order Document Filter [Re: MikeS]
Chris McDonell Offline
Adagio
Loc: Vancouver, BC, Canada
Hi Mike
Try remove the '-'
The '-' is part of the document mask and not actual part of the Document #.
Chris McDonell
Softrak Systems Inc.
#39942 - 01/20/14 12:06 PM Re: Purchase Order Document Filter [Re: MikeS]
Bob Wisener Offline
Adagio Conductor
You show two different versions of that filter. You certainly want to use the 'RC-' version because the document contains the 'RC-'. You could play around with a less restrictive filter like 'containing'. It's always better to start with something that shows you at least one match.
Try Chris' suggestion first. Perhaps I'm wrong about the actual content.
Edited by Bob Wisener (01/20/14 12:07 PM)
Edit Reason: Chris' comments
Bob Wisener
Dakota Software
#39943 - 01/20/14 12:14 PM Re: Purchase Order Document Filter [Re: Bob Wisener]
MikeS Offline
Loc: Concord, On
Thanks Chris,
That was the problem. "RC107894" worked. I thought RC was part of the mask as well since it's pre-defined and when RC-107894 didn't work I moved on.
0 registered (), 70 Guests and 3 Spiders online.
14666 Topics
