#39003 - 10/30/13 11:18 AM
Re: PO 8.1C - mass printing POs to PDF
[Re: Steve Schwartz]
Hi Steve,
You are correct - Purchase Orders is not standard. Sometimes that's life. Because POs can have multiple vendors and different specifications, the documents are handled as separate print jobs. It works the same way in Adagio Invoices when previewing a batch and invoices and credit notes use different specs. Also, Purchase Orders supports viewing the document spec while it is edited, which other applications do not support. Supporting this feature required a rewrite of the printing code in PO that allowed a range of documents in a single job, and thus a single PDF. Which feature do you like better - printing to a single PDF, or having multiple vendors on a PO and being able to view the PO spec while editing?
Are you printing to the AdagioPDF driver? Or Print to File with a PDF destination? Or is Adagio ePrint used? I suspect it is Print to File with PDF format.
When printing to PDF with ePrint, there is no pause between each printing and instead creates all PDFs with just the single click, with customizable file names and storage. Yes, each PDF is a separate file, but there are PDF joiner programs that Google could find for you. Perhaps future releases of Adagio ePrint will have joining capabilities.
Perhaps we can investigate different behaviour when printing POs without the 'Use Vendor PO' option selected, or when printing Receipts, Requisitions or Invoices, as the only choice is to use the Selected Spec on the print documents screen. Though because these documents can have multiple vendors, this is not a guarantee. Better money would be on Adagio ePrint as the eventual solution.
What is the business reason for printing a range of POs or other documents to a single PDF file? For archival purposes?
Regards, Softrak Tech Support
#39010 - 10/30/13 03:19 PM
Since changing the specification (or even thinking that you might have to change the specification) results in the printer being "closed" and "opened", the behavior you do not like is a Windows behavior and beyond our control.
Sorry.
As Support mentioned, we expect to add "combine" functionality to the next release of ePrint.
If someone wants to see all the outstanding PO's, and you not just print the PO report and show them the list?
#39017 - 10/30/13 08:00 PM
[Re: Douglas Dickie]
Adagio Ace
We also need to print a range of POs to a single PDF file in order to e fax or email to our branch managers.
#39019 - 10/31/13 06:57 AM
[Re: Fong]
Loc: Concord, On
Hi Steve,
This probably isn't the neatest solution but it might work. There's an open source program called PdfMerge that allows you so select multiple PDF's and merge them into one file. With 'If Archive PDF customer copy? checked', they would have access to the original PO's (I would copy out the PO's to a sub-directory first - makes it easier to find especially since the files are saved by customer/vendor name). With an excel list of outstanding PO's they could then select the required PO's from within PdfMerge to create a single pdf.
Mike Smith Viktorian Sheet Metal Mfg Inc
#39052 - 11/01/13 05:02 PM
Steve: There is a nice program called PDF Factory which keeps adding files sent to it (from any source) until you stop. I tested it with Adagio PO, and it works fine. (I use it assemble files from different sources, eg. a quote from Excel, a cover letter from Word and selected pages from the latest Adagio catalog.)
1 registered (accountability),
191
Guests and
Spider online. |
