#38271 - 08/21/13 05:49 AM Purchase Order Inquiry
MikeS Offline
Loc: Concord, On
After selecting Inquiries and then Receipts-Primary vendor, I selected Finder (F5) to find a particular vendor. I then entered the first three characters in the Vendor code field. It brought up a blank result. The only way to get a result was to type in the full, proper vendor code.
Purchase Orders 8.1C (130722)
Edited by MikeS (08/21/13 05:51 AM)
#38274 - 08/21/13 08:32 AM Re: Purchase Order Inquiry [Re: MikeS]
Hi, Mike,
PO should be respecting the Vendor formatting as set within Payables' company profile. Thanks for pointing this out to us. I've reported it to R&D for you.
#38280 - 08/21/13 11:03 AM Re: Purchase Order Inquiry [Re: Softrak Support]
I tried to use F6 to search by vendor and I am getting the attached error.
08-21-2013 12-00-08 PM.png (109 downloads)
#38281 - 08/21/13 11:26 AM Re: Purchase Order Inquiry [Re: Patricia B.]
Hi Patricia,
It appears that the smart-finder search on the vendor when using the Find Receipts process is pointing to the wrong dictionary. The @U81CHH8 is the history receipts header smartfinder dictionary, when I suspect it should be looking at the current receipts header smartfinder (@U81CHE8). The reverse is also true where doing a Find on History receipts and a smartfinder search on the vendor field gives a dictionary error, pointing to the Current receipts file.
We'll forward the results to R&D for you.
2 registered (Tanya_Belanger, Howard S.-MMA), 323 Guests and 5 Spiders online.
14627 Topics
