#35397 - 02/07/13 10:00 AM AP Distribution codes
PLane Offline
Casual
Loc: BC
We have been using distribution codes to input costs per truck. I have tried to find a report that then gives a print out based on distribution codes, (which would tell me how much each truck cost me per period) but there doesn't seem to be one. When I look up distribution codes, I am not sure this was what they were intended for. If this isn't what distribution codes were for is there a way of tracking cost per truck without setting up a gl code for each truck.
Patricia Lane
#35401 - 02/07/13 11:16 AM Re: AP Distribution codes [Re: PLane]
Patricia:
Distribution codes are not intended for the purpose you have described and I don't believe they are stored with the transactions in AP.
The solution is to use departments in the GL. One department for each truck.
#35402 - 02/07/13 11:21 AM Re: AP Distribution codes [Re: Douglas Dickie]
Hi Patricia,
The distribution code is not stored on the vendor transactions, though they are stored on the 'GL distribution' sub-file that keeps track of which GL accounts were posted to by a particular AP transaction.
You have an option to use this file for a customized report or GridView inquiry, but Doug's suggestion is likely a better way to go.
#35418 - 02/08/13 08:56 AM Re: AP Distribution codes [Re: Softrak Support]
Hi Patricia
While Doug's solution is good in general, if you have lots of trucks to track, or if you want to get a report that spans a fiscal year, then Adagio JobCost is the ultimate solution.
#35555 - 02/14/13 02:22 PM Re: AP Distribution codes [Re: Softrak Support]
PLane Offline
Casual
Loc: BC
I have checked through export files in the GL as well as reports and I don't see a distribution subfile mentioned. Where could I go to access this information.
#35556 - 02/14/13 02:34 PM Re: AP Distribution codes [Re: PLane]
Hello Patricia:
Unfortunately the subfile that Support referred to neither has a report nor can it be exported. Do you have Crystal Reports or GridView? You would need one of them to do a custom report.
0 registered (), 138 Guests and 0 Spiders online.
14539 Topics
