#3551 - 08/06/03 08:02 PM crpaig32.dll error after Payables upgrade
We have a peer to peer network with adagio installed for one user at a time. I installed the payables update and now on the other computer I cannot print any reports in payables - everything prints fine still in the ledger. I get the following error message - crpaige library crpaige(32).dll cannot be found it should be on the path.
It worked fine before the upgrade.
Thanks, Brenda
#3552 - 08/06/03 08:20 PM Re: crpaig32.dll error after Payables upgrade
Hi Brenda2,
Could you run \softrak\system\chksys.exe from the drive where your Adagio is installed and see if it complains about anything in your setup? Did you make sure that you installed the upgrade to the same drive letter where the original release was installed?
#3553 - 08/07/03 12:09 PM Re: crpaig32.dll error after Payables upgrade
Hi, I ran the chksys.exe program and everything is OK. I did install the upgrade to the same folder etc as the original. I have install numerous update since we got Adagio and have had no problems before this.
Thanks, Brenda
#3554 - 08/07/03 04:09 PM Re: crpaig32.dll error after Payables upgrade
Hi, just to add a few things. Most of the time when I try to print from the workstation in Payables there is no error message, but nothing prints. If I try to do a print preview nothing happens - even if I try to print to screen, nothing happens.
Thanks, Brenda
#3555 - 08/08/03 12:38 PM Re: crpaig32.dll error after Payables upgrade
Hi Brenda,
Typically when you attempt to print a report but nothing seems to happen, this is caused by a missing or non-current report table. The new 6.8B upgrade for Adagio Payables required new tables, so it's possible that after installation the new tables were not installed. Usually CHKSYS would show this.
Search for a QRASP directory on your system, which is where the report tables are found. Look for 3 particular files of format QRTAP_68.QRW, where the _ is replaced by B, W or Z. If you don't have all 3 files (or they are dated earlier than Dec 2002) then you don't have the tables. You can find a copy of them in \softrak\system\qrasp\ap, paste them into your QRASP directory.
The 'crpaig32' error would be different, where a report are expecting the existance of the file crpaig32.dll, which is a Text Object link library. According to our AP release notes, we install this file in case reports are modified. It should be in the C: \windows\system(32) directory.
If you are running Windows 2000 or XP, make sure the workstation setup is run while you are logged into the machine with full installation rights.
#3556 - 08/08/03 02:40 PM Re: crpaig32.dll error after Payables upgrade
This issue is now resolved. For others reading this, the problem turned out to be an incorrect Report Tables drive defined in the Windows Registry. Because of this, the Payables report tables were not being found. When the Registry was corrected, all Payables reports printed as expected.
1 registered (1 invisible), 252 Guests and 0 Spiders online.
14636 Topics
