#32501 - 07/05/12 12:33 PM Re: Task Scheduler Windows 7 [Re: Bruce Gardner]
I use Datacare from Windows Scheduler on Windows 7 without a problem. The computer needs to be only locked. However, the task should be setup to run only when it is logged on. This is ok since it will not run if it is not. The reason is because it uses a mapped drive. And, all the comments made about not being able to use Datacare with an UNC path unless you tweak the location of the report tables.
#32503 - 07/05/12 12:50 PM Re: Task Scheduler Windows 7 [Re: Patricia B.]
Hi, Patricia,
Yes, when scheduling the task on the server and using UNCs, you would also want to copy the QRASP folder to the actual root of the drive, unless the root of the physical drive is also where your Softrak folder is and stations map to it. That isn't normally the case though.
#32527 - 07/09/12 10:13 AM Re: Task Scheduler Windows 7 [Re: Softrak Support]
It seems to be working now.
* Changed it use UNC (ie. \\Servername\Sharename) rather than the drive letter (S:\Softrak\DataCare\DataCare.exe).
* "Run only when user is logged in" is selected and I disconnected rather than logged off.
Impressively, with "Wake the computer to run this task" selected, it actually wakes my computer up out of sleep and runs the task.
I'll keep an eye on it this week but so far so good!
0 registered (), 124 Guests and 0 Spiders online.
1869 Members
14602 Topics
