#29558 - 11/02/11 11:30 AM check number in Bank Rec
Michael2011 Offline
Adagio Groupie
Loc: BC
I used to be able to enter "." and "/" in this field, such as
"Oct/11.remit".
but for some unknown reason, now it will only take "Oct11remit".
also, the system does not keep the setting for allowing alphanumeric in this field.
I have to keep going back into AP/edit company profile and check the setting on batch/vendor.
Please help.
#29559 - 11/02/11 11:45 AM Re: check number in Bank Rec [Re: Michael2011]
Michael2011 Offline
Adagio Groupie
Loc: BC
UPDATE TO MY PREVIOUS POST:
I can enter "/", ".", or "," if it is receipt.
I cannot enter "/", ".", or "," if it is a payment.
#29560 - 11/02/11 12:15 PM Re: check number in Bank Rec [Re: Michael2011]
Hi Michael
Pending tech support's answer, see whether in AP Company Profile, Batch/Vendor tab, that "Alphanumeric manual check numbers" is checked.
If it is, let us know what version and release date you are running for BankRec and Payables.
#29562 - 11/02/11 01:26 PM Re: check number in Bank Rec [Re: Steve Schwartz]
Michael2011 Offline
Adagio Groupie
Loc: BC
AP: 8.1C(100810). Could not find release date.
BR: 8.1C(110512).
above info taken from help / about.
I have to go into AP Company Profile, Batch/Vendor tab, that "Alphanumeric manual check numbers" and check the box last month due to this issue.
and this month, I have the same issue and have to check the box again.
I am pretty sure (99% sure?) that we did not change the setting in both cases.
#29563 - 11/02/11 03:49 PM Re: check number in Bank Rec [Re: Michael2011]
Hi, Michael,
I'm not finding that the setting is changing in my Company Profile at all. It's the same as it was a month ago - enabled.
Yes, using the versions you are, in both AP and for BR check numbers, you are able to use letters and numbers only in alphanumeric manual check #s. You are not able to use dashes or slashes. This has been noted for R&D.
Again, yes, in AR and BR, you are able to enter a dash or a slash (along with letters and numbers) within the cash receipt #.
#29567 - 11/02/11 04:18 PM Re: check number in Bank Rec [Re: Softrak Support]
Michael2011 Offline
Adagio Groupie
Loc: BC
THANK YOU!
