#28896 - 09/16/11 06:15 AM Gridview - Help!
Using the table "*OE Ord Detail w Head, Head Ext", the field "Print Status" appears as 0, 1 or 2. How can I tell Gridview that if the status is 0 to display "not printed, if the status is 1 to display "back order printed" and if the status is 2 to display "pick list printed"?
#28897 - 09/16/11 06:26 AM Re: Gridview - Help! [Re: SusanTennier]
Warren Karges Offline
Hi Susan, the option you're looking for is called "Translate coded fields", you can enable it by editing the table's definition.
Warren
#28898 - 09/16/11 06:30 AM Re: Gridview - Help! [Re: Warren Karges]
"Translate coded fields" is checked.. but it still displays as 0, 1, 2.
#28901 - 09/16/11 06:56 AM Re: Gridview - Help! [Re: SusanTennier]
Hi Susan
I just created a view matching your description above, and when I turned on "Translate coded fields", the print status field changed from numbers to words. So it should work for you too.
I am using version 9.0C (101001).
#28903 - 09/16/11 07:03 AM Re: Gridview - Help! [Re: Steve Schwartz]
Maybe because mine is a linked view?
#28904 - 09/16/11 07:52 AM Re: Gridview - Help! [Re: SusanTennier]
Try it as a not-linked view and see what you get. Or even just create the simplest possible view with the Print Status field on there and prove me wrong (or right).
#28907 - 09/16/11 09:04 AM Re: Gridview - Help! [Re: Steve Schwartz]
I did.. but still not working.. haven't figured it out.. hmmm
#28910 - 09/16/11 09:31 AM Re: Gridview - Help! [Re: SusanTennier]
When I use the table from OE it works as you describe, but it doesn't work when using the table from the Composite Tables.
#28912 - 09/16/11 09:39 AM Re: Gridview - Help! [Re: SusanTennier]
The OE Table has all the fields I need so I switched tables and it's good now. Thanks!
0 registered (), 103 Guests and 1 Spider online.
14599 Topics
