#28318 - 08/08/11 09:54 AM Error code running ODBC after Lanpak 9.0D upgrade
Tai Offline
New Guy
I'm getting an Assertion Error code when running ODBC after Lanpak 9.0D upgrade.
"File none, Line 586. Yes to invoke debugger, Cancel if debugger already running, No to ignore." When I press No, ODBC runs as normal.
Tai
#28321 - 08/08/11 10:53 AM Re: Error code running ODBC after Lanpak 9.0D upgrade [Re: Tai]
Is the error coming from ODBC or your application? Can you load a customer list into Excel without error?
#28324 - 08/08/11 11:58 AM Re: Error code running ODBC after Lanpak 9.0D upgrade [Re: Retired_Guy]
Tai Offline
New Guy
I originally thought the error was from our other application but when I ran it with excel using a pre setup connection, I did get the error but it ran fine after clicking on No. However, I tried to set up new a connection with excel and had a message "This data source contains no visible tables". Data did not load.
#28328 - 08/09/11 09:22 AM Re: Error code running ODBC after Lanpak 9.0D upgrade [Re: Tai]
Installing your 9.0D lanpak will have replaced the file ADS32.DLL in the \Softrak\system Folder. You might try copying back the backup copy the install should have made. There's no specific need for the 9.0D Lanpaks with ODBC. You'll need them for Ledger though.
#28344 - 08/10/11 11:34 AM Re: Error code running ODBC after Lanpak 9.0D upgrade [Re: Retired_Guy]
Tai Offline
New Guy
Our application that uses ODBC does need Lanpak to work and it is on a different server. We just did a restore to the previous versions and did the upgrades again except for the Lanpak with ODBC. Everything now works perfectly. Thanks!
Tai
#28351 - 08/11/11 07:38 AM Re: Error code running ODBC after Lanpak 9.0D upgrade [Re: Tai]
OK - glad to hear it.
We'll see if we can recreate your problem when vacations are completed next week.
Thanks for your patience.
#28371 - 08/12/11 06:53 AM Re: Error code running ODBC after Lanpak 9.0D upgrade [Re: Retired_Guy]
Darren Offline
Stranger
I am having the same problem, although I have 6 different companies set-up on the same server. Five of them work fine, the 6th one (the largest one) causes the error.
Is the updated Lanpak required or can I go back to the old version?
#28372 - 08/12/11 06:58 AM Re: Error code running ODBC after Lanpak 9.0D upgrade [Re: Darren]
Thanks for letting us know you are experiencing the same problem. Can you connect using Excel?
As my previous post stated, there was no specific need to install the new Lanpaks just for ODBC. The lanpaks were required for Ledger and later upgrades.
#28375 - 08/12/11 08:33 AM Re: Error code running ODBC after Lanpak 9.0D upgrade [Re: Retired_Guy]
Darren Offline
Stranger
We do use Ledger. When I try to connect from excel, excel crashes with an error in the .exe file.
I swapped out the ADS32.DLL with the backed up version, and the error still appears.
#28623 - 08/26/11 06:56 AM Re: Error code running ODBC after Lanpak 9.0D upgrade [Re: Retired_Guy]
Hello Support:
I have a client using ODBC for EDI processing. They were getting the message: "Assertion error, file non line 586. Yes to invoke debugger. Cancel if debugger already running". This error occurred after installing the latest versions/service packs of GL/LP/AR/OE/IC.
I rolled back to an older ADS32.dll (Oct 2010) to temporarily solve the problem.
Questions:
  • Does an older ADS32.dll cause a problem running recent modules?
  • The new ADS32.dll is more than twice the size of the older one. Is that correct?
  • When do you anticipate a fix?
Thank you.
1 registered (Samuel Kopstick), 71 Guests and 3 Spiders online.
1866 Members
14518 Topics
27 28 29 30 31
