#2813 - 11/07/02 03:35 PM Printing Cheques in AP 6.8A (010913)
Ken A. Offline
Loc: Kamloops, BC
We are trying to print cheques on pre-printed forms through the above AP version. Using either the manual or invoice cheques when we go to print, we get the following message:
"Printer out of Index Range"
We have tried to print to our HP 1200 which is local on one workstation and shared to our other three and also to our Cannon 5000 network photocopier/printer, with the same results?
Any ideas?
Ken
#2814 - 11/07/02 06:27 PM Re: Printing Cheques in AP 6.8A (010913)
Hello Ken
The shipping version of Adagio Payables may resolve the problem with 'Print Index out of Range' depending on what exact procedure is causing the problem. Since you're on a current Upgrade plan, you can download this from the End User area of our website.
For instance, how are you 'selecting' the check printer? Is it by default the printer that shows up in the print options screen?
A similar error was reported when trying to select a different printer 'tray' in this area, but this has been fixed in the current shipping version.
You could try using the Payables Edit-Banks area to select the printer that checks are to be printed to, or in the File-Options area, selecting a 'Specific' printer to print the checks to instead of having to change the printer in the print options screen. (Or do both) to see if this helps.
Regards
14617 Topics
