#28095 - 07/21/11 10:12 AM Lanpak 9.0D and Inventory SP "breaks" Ledger
If you have installed Adagio Ledger 9.0D Lanpaks or Adagio Inventory V8.1C (110713), you will shortly discover (if you haven't already)that the Financial Reporter in Adagio Ledger stops working.
A change in our database layer installed with both these modules is the cause. The change was made to support some new features planned in future upgrades across the product line. We have frozen the downloads until a fix has been produced and uploaded, at which point this announcement will be revised, and would ask that you discard either of these two downloads if you have them.
Only a few individuals have downloaded these releases. We will post a solution as quickly as possible.
Sorry for the inconvenience.
#28108 - 07/21/11 11:35 PM Re: Lanpak 9.0D and Inventory SP "breaks" Ledger [Re: Retired_Guy]
A SysUpdater is available on the web which fixes this issue.
Sorry if you were inconvenienced.
#28109 - 07/22/11 03:04 AM Re: Lanpak 9.0D and Inventory SP "breaks" Ledger [Re: Retired_Guy]
Hi Andrew
I installed the SysUpdater, launched GL 9.0C, and the FR still stops working and exits. I checked under Help, and the ADS32 version matches the release notes, so I know the install was successful.
#28113 - 07/22/11 07:04 AM Re: Lanpak 9.0D and Inventory SP "breaks" Ledger [Re: Steve Schwartz]
Had you accessed the data with Ledger V9.0D? Make sure that you are accessing Ledger 9.0C data with the FR.
From the release Note:
Quote:
If you are upgrading from Ledger 9.0A or 9.0B a minor database conversion will be performed the first time you open your database with Adagio Ledger 9.0D. Starting the GL9.0D Financial Reporter also modifies the GLACCGRP file and as a result earlier versions of the GL will no longer be able to access the Financial Report for that database.
#28115 - 07/22/11 08:46 AM Re: Lanpak 9.0D and Inventory SP "breaks" Ledger [Re: Retired_Guy]
Steve:
Installing the SysUpdater resolved this issue for us.
#28116 - 07/22/11 08:48 AM Re: Lanpak 9.0D and Inventory SP "breaks" Ledger [Re: Douglas Dickie]
Andrew:
Have new installs of IC Service Pack and LP Upgrade been put up on the web with the new ADS32.DLL?
Edited by Douglas Dickie (07/22/11 08:53 AM)
#28121 - 07/22/11 10:07 AM Re: Lanpak 9.0D and Inventory SP "breaks" Ledger [Re: Douglas Dickie]
Michael Mulrooney Offline
The plan is to update the Web on Tuesday...
The GLACCGRP mentioned above in Andrew's post should be GLRPTGRP. Deleting it will allow you back in with GL 9.0C
#28135 - 07/25/11 11:26 AM Re: Lanpak 9.0D and Inventory SP "breaks" Ledger [Re: Douglas Dickie]
New installs for Lanpak and Inventory are now available on the web for download.
End user notifications regarding availability should be out shortly.
There is no need to use the SysUpdater if these downloads are used to install the new LanPaks or Inventory Service Pack.
#28284 - 08/05/11 12:51 PM Re: Lanpak 9.0D and Inventory SP "breaks" Ledger [Re: Retired_Guy]
Marianne Offline
Accounts Payable
Loc: Surrey, BC Canada
SysUpdater? Do I just go to Downloads and will find that update? Sorry, I just don't have much time to scan the updaters, I am so behind with my July month end report so my priority is to fix all errors as quickly as possible.
#28285 - 08/05/11 12:57 PM Re: Lanpak 9.0D and Inventory SP "breaks" Ledger [Re: Marianne]
Marianne Offline
Accounts Payable
I checked the service packs but there's no update for ledger 9.0D yet. My problem again is "Financial Reporter stopped working"
