#28020 - 07/15/11 06:32 AM GridView - IC Bill of Material Detail file
I am trying to create a simple report in GridView that shows the components on a bill of material. Is there any way to add to the report the component description. The item description is not a field that is part of the BOM Detail file.
It seems that when I copy over the description field from IC Items I get the master item description, not the component description.
If not, can I make a suggestion that this be allowed?
#28022 - 07/15/11 08:18 AM Re: GridView - IC Bill of Material Detail file [Re: Steve Schwartz]
Hi, Steve,
I see what you mean. I'll look into this for you.
#28027 - 07/15/11 09:02 AM Re: GridView - IC Bill of Material Detail file [Re: Softrak Support]
Hi, Steve,
Okay, this is how you do it.
Either copy the Description column from the IC Master (1) table view to the IC BOM List Detail table view or use the Edit | Insert Related Column function.
Then, edit the Description calculated column and change the last parameter from {Master Item #} to {Component Item #}.
The formula becomes: GETEXTERNALDATA("@N81CICM", "Description", "ICITEM", {Component Item #})
This is working for me.
#28036 - 07/16/11 06:34 AM Re: GridView - IC Bill of Material Detail file [Re: Softrak Support]
Hi Leigh
That worked beautifully for me too.
Thanks so much!
