#25563 - 12/29/10 08:32 AM Forecasting Sales by month
ender Offline
Adagio Groupie
Loc: ontario, canada
I am looking for help in deriving sales history by quantity and month by item all at once. Is this at all possible?
Ender
#25565 - 12/29/10 09:49 AM Re: Forecasting Sales by month [Re: ender]
Yes.
Do you have Adagio SalesAnalysis? Are you using Adagio OrderEntry or Adagio Invoices?
#25567 - 12/30/10 05:18 AM Re: Forecasting Sales by month [Re: Retired_Guy]
ender Offline
Adagio Groupie
I am using Adagio Sales Analysis...I have used it to download one month or period at a time to make up for the entire year onto a spreadsheet.
There must be an easier method.
Also, is there a method of setting up a default in the system for taxes. For example, we tax our customers on Fertilizer sales under 500 kg. This would mean multiple varieties totalling that amount.
Is there a way in order entry to allow a default that states that if the total sum is less than 500 kg, an automatic tax is calculated.
Thanks and regards,
Ender
#25568 - 12/30/10 06:31 AM Re: Forecasting Sales by month [Re: ender]
Hi Ender
Yes, there is an easier method in SalesAnalysis. You should add the Amount field as a selected field 12 times, each time changing the Field Title, specifying "MTD" as the Date Range, and changing the Interval from 0 to 11 for each instance. Then when you view the inquiry, choose the ending date. It will put all 12 months side-by-side.
You should post the tax question as a different topic. It's best not to combine two unrelated subjects in one topic (by the way, I don't know that answer to that one)
14630 Topics
