#24594 - 10/22/10 07:49 AM Copy journal entry from one company to another
Vicky Offline
Stranger
Loc: Toronto
We have multiple companies set up on Adagio. I have an open batch in the g/l for one company that I will have to post again to a second company. Is there any way to copy this batch to the second company? It's a long entry and I don't want to have to do the work twice.
thanks,
Vicky
#24595 - 10/22/10 08:29 AM Re: Copy journal entry from one company to another [Re: Vicky]
Hi, Vicky,
What version of Ledger are you using? What you would do varies between v8.x and v9.0 Ledger. In Ledger 9.0B, we added the File | Export | Batches function. You could export the batch to an export file in a common folder on the server. Then, in the other company's dataset, they could File | Import | Batches the batch by pointing at the file and location the original batch had been exported to.
#24596 - 10/22/10 08:56 AM Re: Copy journal entry from one company to another [Re: Softrak Support]
Vicky Offline
Stranger
Loc: Toronto
We are using 9.0. I see the export function on the drop down menu. The batch export is there, but it is the only function that I cannot access. I can access the export accounts, tranasactions and all the others except the batch function.
#24597 - 10/22/10 09:03 AM Re: Copy journal entry from one company to another [Re: Vicky]
Hi, Vicky,
Doesn't sound like you've been granted access to that function. Speak with your Adagio system administrator and explain what you want to do. They should be able to help.
0 registered (), 107 Guests and 1 Spider online.
